Hi can anyone help me with my A3 1.8T Quattro that has the following issues.
My car is bouncing around when idling, it's not bouncing much but the needle is moving up & down & I can feel a judder in the car, this is whilst sitting still.
When driving along normally if I'm stopping I put the clutch down and the rev's drop to 500 then quickly go back to slightly over 700 again, just over 700rpm is normal, this is also the case if I start the car when it's warm, when cold it's ok but I guess thats the auto choke, however when first pulling away for the first few times the car is very sluggish.
When I change gear I dip the clutch and the car jolts, it's not a smooth as it was, seems very jerky - especially pulling away.
I do hear a slight rushing of air sound coming from the engine bay, I think from the drivers side but I can't see anything obvious or hear anything with the bonet up, this noise can't be heard when the car is not moving, it only appears whilst the car is accelerating.
Very poor MPG's, normally I get 32mpg but getting around 26mpg's seems to be peeing fuel, not a cheep habit just now .
I've tried the following to remedy the issues
Changed MAF sensor
Changed Spark Plugs
Changed Air Filter
Cleaned Throttle Body Housing + reset ECU
Oil was low so I've topped up again as this A3 is one of the oil guzzlers
CTS
Coil Packs
DV replacement
Lambda probe "following some errors on VAG COM"
I've had a check around the pipes and connections but cant see anything obvious.
I've run VAG COM tonight which has pulled up some lambda related errors however the lambda was replaced 2-3 months ago and surely can't be the issue - this A3 only has the 1 lambda probe and it's pre cat.
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 06A 906 032 R
Component: 1.8L R4/5VT 0004
Coding: 05600
Shop #: WSC 06435
2 Faults Found:
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1J0 907 379 AG
Component: ABS/EDS 20 IE CAN V009
Coding: 13504
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Controller: 8L0 820 ö8
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8L0 920 980 C
Component: AB-KOMBIINSTR. VDO D11
Coding: 05444
Shop #: WSC 00000
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1469258
Address 22: AWD
Controller: 02D 900 554 B
Component: HALDEX LSC ECC 0006
Address 35: Centr. Locks
Controller: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D13
Coding: 15210
Shop #: WSC 00652
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
Address 56: Radio
Controller: 4B0 035 186 D
Component: Radio 0001
Coding: 00207
Shop #: WSC 06435
1 Fault Found:
00852 - Loudspeaker(s): Front
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
Any help would be really really appreciated.
Changed MAF sensor
Changed Spark Plugs
Changed Air Filter
CTS
Coil Packs
DV replacement
Address 01: Engine
Coding: 05600
Shop #: WSC 06435
2 Faults Found:
P1113 - 35-00 - -
Coding: 13504
Shop #: WSC 06435
Coding: 05444
Shop #: WSC 00000
Address 22: AWD
Coding: 15210
Shop #: WSC 00652
Coding: 00001
Shop #: WSC 00000
Address 56: Radio
Coding: 00207
Shop #: WSC 06435
1 Fault Found:
