JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
    Mcblow's Avatar
    Jun 2008
    82
    Dump valve flutter??
    Me and a mate of mine both have 1.8t's,they have both been remapped by the same place,both have split-r dv's,the difference being mine is a dbw quattro,his is a cable throttle front wheel drive,his dv makes a loud (ish) dump sound,where as mine seems to flutter???....is there a problem as i can't work out why there is such a big difference in the sound they make??
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    Looking for 2002/3 Red S3 below 80k and £6k
    www.dubsuffolk.com
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    prob becuase yours is a quattro which has a differnet turbo,and will be runing more bhp than a 2wd,correct me if im wrong lads.
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
    Mcblow's Avatar
    Jun 2008
    82
    it is slighty more bhp,your right there,but not alot more,and i keep getting told mine will have a ko3 by some people and a ko3s by others,because it dbw??,so if i have the same turbo and only 12-15bhp more,why the big difference in sound,don't get me wrong,i don't want mine loud,just worried incase sumats wrong!!
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    www.dubsuffolk.com
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    not sure mate.i know the quattro has 180bhp and a ko3s turbo and the 2wd has 150bhp with a ko3 turbo.so the 2wd with re-map prob has 185bhp and the quattro prob around the 225bhp i think??..prob sounds different becuase of the psi...or maybe just a leaking pipe or hose etc mate.
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    sounds like you might have to adjust the spring tension abit they may have set them both up the same, turn the adjuster disc on top the valve where the vacum hose joins clockwise 1 or 2 turns then try it, may need 1 more if still not right
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Have a look at my post from a couple of days ago: http://audi-sport.net/vb/showthread.php?t=62730
    The advice I was given was that the dv is knackered and may be the reason behind the slight surging I get. I've picked up a genuine one from the stealers today and will fit it on the weekend. I'll report back the findings then.
    Mcblow's Avatar
    Jun 2008
    82
    Quote Originally Posted by steviet View Post
    sorry just want to check this,i have a 2000 DBW quattro,does this have a ko3s??
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    www.dubsuffolk.com
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    it's all about the engine code in adraid matey.....
    give us the engine code on the front drivers side of the head and we can tell you what turbo is should have!
    2000 was the changeover year....
    Mcblow's Avatar
    Jun 2008
    82
    ajq...i have read a post on here that says the ajq throttle cable has a ko3,but another post claiming the ajq dbw has ko3s???
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    www.dubsuffolk.com
    Mcblow's Avatar
    Jun 2008
    82
    Quote Originally Posted by s3_kev View Post
    gonna try tightening tomoz
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    www.dubsuffolk.com
