Volks AutosEM Tuning
Results 1 to 9 of 9
    May 2008
    Middleton, Manchester
    43
    A3 Idle issue, help needed
    hello guys,
    i have a 1.6 A3 1998 model.
    low end revs are bouncing and can stall whilst slowing down. is this issue to do with the idle valve or something else?
    also what would the cost to rectify this?
    thanks in advanced
    Graham
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    do a search mate, a common issue - air related so first check your air intake system
    Turbo Sport, Auto (I know!), A lot of 's -and rising [latest add: Recon'd. tranny] sunk in her since Aug. 07...
    May 2008
    43
    hmmm MAF?
    get somec arb cleaner on it? this may work!
    thanks
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    Maf is possible, but could also be the air filter etc...best to look at the simple things first..
    Jun 2003
    World of my own
    9,813
    Could also be temp sender, is it worse or the same when the car is cold or hot?
    Alex Turner
    May 2008
    43
    TBO i havent noticed but my brother said its a begger to start in the cold
    Jun 2003
    World of my own
    9,813
    Temp sender would be the best place to start, sounds like it's giving the ECU duff info. The ECU will adjust the fuel/air mix based on this duff info, so stalling, bad starting and idling issues will result. A new one is only 20 from your dealer and is an easy DIY fit.
    Alex Turner
    May 2008
    43
    Quote Originally Posted by AndyMac View Post
    andy thats ace i fouind a new one on ebay for 12.50 would this be listed i the haynes manualas i have one!
    dot32's Avatar
    Aug 2003
    ewell, surrey
    47
    Do you need to reset anything when replacing the temp sender?
