Chris NottSky Insurance
Results 1 to 10 of 10
    Mar 2003
    Durban, South Africa
    14
    A3 T Climate controle Factory Codes
    Hi all
    On the A3T's climate controle you can use some factory codes to get some info on your car. Is there any one that knows what the code is for charge air temp ?.
    May 2004
    81
    Re: A3 T Climate controle Factory Codes
    From what is posted elsewhere on the forum, the cc can tell you what the settings are etc, but you need VAG com to change them.
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,106
    Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
    NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
    Code Displayed Value
    1 System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
    2 Digital value of Interior Temperature Sensor, in Headliner (G 86)
    3 Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
    4 Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
    5 Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
    6 Digital value of Outside Air (Ambient) Temperature Sensor
    7 Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
    8 Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
    9 Delta value of Temperature Regulator Flap
    10 Non-corrected specified value of Temperature Regulator Flap
    11 Digital value of Central Flap Motor Potentiometer (G 112)
    12 Specified value of Central Flap
    13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
    14 Specified value of Footwell/Defroster Flap
    15 Digital value of Air Flow Flap Motor Potentiometer (G 113)
    16 Specified value of Air Flow Flap
    17 Vehicle Speed (km/h)
    18 Actual Air Blower voltage (Volts)
    19 Specified Fresh Air Blower voltage (Volts)
    20 A/C Compressor (A/C Clutch) voltage (Volts)
    21 Number of low voltage occurrences, non-transient
    22 Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
    23 Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
    24 Cyclings of the switches, absolute non-fluctuating
    25 Analog/Digital value, Kick-Down Switch
    26 Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
    27 Coding value
    28 Engine Speed (RPM)
    29 A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
    30 Software version
    31 Display check (all segments of A/C Control Head display light up)
    32 Potentiometer malfunction counter, Temperature Regulator Flap
    33 Potentiometer malfunction counter, Central Flap
    34 Potentiometer malfunction counter, Footwell/Defroster Flap
    35 Potentiometer malfunction counter, Air Flow Map
    36 Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
    37 Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
    38 Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
    39 Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
    40 Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    41 Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
    42 Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
    43 Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
    44 Vehicle operation cycle counter
    45 Calculated interior temperature (internal software, in digits)
    46 Outside (ambient) temperature, filtered, for regulation (internal software)
    47 Outside (ambient) temperature, unfiltered, (internal software, in deg C)
    48 Outside (ambient) temperature, unfiltered, (in digits)
    49 Malfunction counter for speedometer (vehicle speed) signal
    50 Standing time (in minutes)
    51 Engine Coolant Temperature (ECT) in deg C
    52 Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the 88.8 display. See chart below.
    53 Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the 88.8 display. See chart below.
    54 Control characteristics
    55 Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
    56 Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
    57 Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
    58 Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
    59 Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
    60 Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
    61 Software version (latest)
    Mar 2003
    14
    Thanks for the info. Do you get similar codes for the new range of A3's and A4's ?
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,106
    No idea mate!
    darkspin's Avatar
    Mar 2004
    Surrey
    44
    i saw this on TSN too but someone said C27 is the engine speed - is this true?
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,106
    I've only used C17 - speed in km/h. Does anyone know if this can be changed to mph?
    Oct 2003
    Wilmslow Cheshire
    336
    engine speed wouldnt wrk 4 me !
    Feb 2003
    Lincolnshire/Bournemouth
    739
    are there any settings that beep for unmarked police cars?
    darkspin's Avatar
    Mar 2004
    Surrey
    44
    [ QUOTE ]
    [/ QUOTE ]
    if only [img]/ubbthreads/images/graemlins/crazy.gif[/img]
