AH FabricationsVolks Autos
Results 1 to 8 of 8
Thread: Cost of repairs
    Slick S3's Avatar
    Dec 2006
    120
    Cost of repairs
    Just to see hwt you guys think of these prices i got quoted from an independant audi specialist....prices include supply of part, fitting and vat.
    Front top suspension monutings and bearings 168
    front anti roll bar and bushes 178
    rear anti roll bar and bushes 164
    both cv gaitors on osf driveshaft 150
    outer cv gaitor on nsf driveshaft 129
    pre catalist lambda probe 211
    Throttle body clean and set 68
    Its a shock to say the least, what bits would be i be better off buying myself and getting a local mechanic to fit.
    Any feedback would be great guys
    S3 210bhp, facelift, black, 18" RS4's, heated electric leather recaro's, light tints, arm rest, electric sunroof.
    Slick S3's Avatar
    Dec 2006
    120
    anyone!
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    I did front ARB links a couple of weeks ago. 116 including labour, and using genuine Audi parts.
    Not done any of the others...
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    jimbobery's Avatar
    S3
    May 2008
    257
    Throttle body clean and set 68!!!! If you have access to vagcom its very easy to do yourself. Four bolts and one jubilee clip to remove. Spray with carb cleaner to clean (2 halfords). Get a new paper gasket (1.10 from audi). Refit and run the throttle body realignment procedure on vagcom (http://wiki.ross-tech.com/index.php/...Alignment_(TBA))
    Slick S3's Avatar
    Dec 2006
    120
    that does sound a lot for just cleaning the throttle body, but unfortunately i don't have a vag-com! thinking of buying one though.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    are you replacing the ARB with a uprated one either R32 or H&R ??? It seams strange that the front and rear are amost the same price as the rear is easy to do and takes at least 1/2 the time of the front one. Deffo worth upgrading them as the std one is sleved and that splits on the S3 whereas the R32 one isnt sleved. (same bush used for both )
    also only 21 difference between 1 cv boot and 2 .... seems odd but maybe he hasn`t itemised it all correctly.
    top mounts take almost as long as fitting new spring and shocks so sounds about right.
    a lot of those jobs are quite easy DIY stuff, Front ARB is the hardest of the lot probally.
    cv joints require a tool to do the clamps up that hold them on and it can be tricky doing the CV boots if things wont come apart like track rod end nut.
    red to red black to black blue to bits
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    get some quotes elsewhere and compare
    ^^ In my opinion
    Audi_Alex's Avatar
    Apr 2008
    Milton Keynes
    57
    I need to get some similar things to what Slick needed so i got a price for top mounts: 82.50 + VAT per side, front Driveshaft CV Boots inner and outer replaced: 109+VAT per side.
    Seems pretty cheap compared to above, and that was Inde Tech in Milton Keynes. If I had ramp, i'd have a go myself... never mind!
    2000 Audi S3
