Sky InsuranceJMB Retrofits
Results 1 to 15 of 15
    Oct 2008
    Audi A3 1.6 2000 gear knob?
    Hello,
    I'm from denmark, and i need at gear knob for my car.
    I have tried to fitting a S-Line. But the connection is not smilair as my old one.
    What original gear knob/gaiter do i need for my car?
    I hate the stock one, so i will prefer another S-Line or S3 series.
    Regards Mads, Denmark
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    The fitment on the 1.6 gear-knob is different to that on the 1.8, 1.8T, 1.8TQ, S3 (which are all the same)...
    There may be some similar fitment ones from Golfs? I'm not certain though.
    Your only other option is aftermarket...
    Regards,
    Rob.
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    Oct 2008
    Quote Originally Posted by FactionOne View Post
    Regards,
    Rob.
    But i guy from this forums manage to fit the excact same gear knob the i just buyed.
    i have the excact same midterconsole and gearknob. But my knob has a hole different mounting system.
    Please help me!
    Oct 2008
    I need some replys, please somebody.
    Help me
    TQS Collective
    Apr 2012
    54
    Talking
    Quote Originally Posted by sHOIKAW View Post
    Help me
    I know this is a old thread but I did this mod recently. Looks exactly like the picture so no point in posting another. The facelift gaiter frame is smaller so you have to pull both gaiters off of their frames and mate the new one to the old larger frame. Soak the bottom of the new gaiter in hot water for a while and the leather softens up allowing you to stretch it over the larger frame. I couldnt re-staple the gaiter to the frame as the staples in my gun kept crumpling when I tried to shoot them in. Instead I drilled a series of small holes and stitched the leather to the frame. It's a bit of a hassle but its completely worth it afterwards
    Nov 2013
    22
    Is that a 5 speed or 6 speed gear knob? I have an a3 8l 1.8t and would love something a bit oem+ instead of the original one.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    Thats a 5 speed gear knob
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    Nov 2013
    22
    Do you what its from? Will it fit my 8l a3? Cheers
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Looks like an 8p gear knob which will fit,
    Have a look at this mate:
    New S3 (8P) Gearknob
    2002 S3 REVO
    Nov 2013
    22
    Cheers mate, ill be on the lookout for a 5 speed one for my a3. mine is a pre facelift model, im assuming that the how to guide you have in that link is the same?
    Nov 2013
    22
    Im assuming this will fit
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Yes mate that will fit no problem
    2002 S3 REVO
    TQS Collective
    Apr 2012
    54
    Quote Originally Posted by Southa399 View Post
    Just to let you know, it won't fit directly. Mine is also a Pre-facelift, read through what I wrote above, all the newer style gear knobs are for facelift models onwards and the gaiter frame for those are smaller than our facelift ones. You will have to use the old frame on the new gaiter as I have described above. Also look at the listing, its 2000-2003 models = Facelift.
    Also worth mentioning that the gear knob you've found on ebay isn't going to look like the picture above. The one you've shown listed is a lower spec one possibly a knock off. The one in the picture is grey and the leather is a bit more plush giving a more perforated look
    Nov 2013
    22
    Yeah I dont intend to buy rhe one I pictured as its far to cheap to be any good lol, was just using it as a reference. Is it hard to fit the new gaiter to the old frame? I understand you heated it with hot water but how easy was it to do all in all. Cheers mate
    TQS Collective
    Apr 2012
    54
    Well you have to be able to do basic hands on work, its not too hard. While the leathers softening, drill little holes through the frame (where the staples were just as a guide). Then once you've stretched the leather over the frame its all about patience while you stitch it together, up to you what method you choose, I used a thicker than normal thread and made sure it was on tight, may not be neat but it cant be seen. Its also worth mentioning that the staples come out quite easily with a flat head screwdriver but just be careful not to rip into the leather.
  1. Audi A3 6 Speed Manual Gear Knob + Gaiter
    By JRock247 in forum For Sale/Wanted - Audi Parts
    Last Post: 18th June 2013, 13:24
  2. Replies: 1
    Last Post: 23rd August 2010, 15:08
  3. Came accross an Audi R8 wheel and gear knob
    By WKDLAD in forum R8 Forum
    Last Post: 24th April 2008, 13:53
  4. audi a3 Gear knob replacment HELP!
    By ridgea3 in forum Tuning
    Last Post: 16th August 2006, 07:07
  5. HELP!!! Audi S3 Gear Knob
    By chuckys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2004, 20:55
