[ QUOTE ]
ANDYTQ said:
How about the S3 standard suspension for sale on here.Works on mine and drills and its a cheap upgrade.Cheers Andy
[/ QUOTE ]
An S3 set up would be a slight improvement...but to be honest, it's still awful.
You can persevere with the S3 stuff for years...but you simply can't get the car to handle properly.
The only way you are actually going to drastically improve the handling is to fit a decent quality set of springs and dampers.
I use Bilstein Sport dampers and H&R springs...a combination I'd recommend.
If you only want it to look better...change the springs only, and it'll look better but drive badly.
If you want it to look good and handle better...change the springs and dampers - as you suggested.
If you really want a transformation in handling you're going to need to look at springs, dampers, front & rear anti-roll bars and an aggressive suspension set up.
That can give you a handling set up as good as the Subarus / Evos, if set up correctly.
I would think that the S3 and A3q aftermarket springs would be interchangable, so you could get a set of lowered springs for an S3/A3q and match them to either A3q or S3 sports dampers.
That'll give a nice improvememt as long as you pay attention to the suspension settings...don't go for standard...that only adds to the understeer problems of the standard car.
Basically, and quality spring and damper combination will yield a good improvememt...but you'll have to set it up aggressively to make the most of it.
Don't forget that you'll probably end up with too much rear negative camber after you've lowered it..so you'll beed to budget for a set of adjustable rear arms to sort that out.
