Badger5Sky Insurance
Results 1 to 9 of 9
Thread: Over rev
    Oct 2008
    60
    Over rev
    i have a golf with s3 amk engine in and when im giving it some and change gear it over revs when i change im wandering if this is just an amk thing or if its something common i can fix
    Thanks guys pretty new here so be gentle
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Either you can't change gears properly or the clutch pedal switch is knackered (less likely ).
    The part is around 8 from Audi and doesn't take too long to change over, but it can be fiddly. It's a common problem on the 1.8T engines.
    Oct 2008
    60
    a mechanic for vw said it over revd and also another chap so defo not me lol
    to be fair i thought it was cos i was crap because sometimes its worse then others
    Oct 2008
    60
    how much would a garage charge to fit you reckon
    Oct 2008
    60
    i also read this only makes a difference if u have cruise control i do not ?? or is this false
    807
    I think this is false, i thought they all had the clutch switch/sensor.
    As iirc if you press the clutch the sensor will drop the revs?
    Trick's Avatar
    Sep 2008
    161
    My S3 Does the exact same thing! clutch down and revs keep going (only for bout 1 sec) Whats goin on
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Clutch pedal switch (as above)
    What Mk golf have you put the engine in?
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Oct 2008
    60
    mk4 buddy
