EM TuningChris Nott
Thread: bumps in tyres
    bumps in tyres
    ok guys/gals i got a really small bump on my rear right tyre...
    It looks insignificant - my question - IS IT?
    Its about 1 inch diameter and not high and pronounced at all.
    SHould I worry...
    Obvioulsy don't want to change two tyres, is it ok if i change one...they are new.... [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Nottingham
    466
    Re: bumps in tyres
    Got any pics?
    If not I WOULD take to a tyre specialist to make sure. You don't want a random blow-out at high speed. A couple of hundred quid is worth more than your life [img]/ubbthreads/images/graemlins/angel.gif[/img]
    Hants
    223
    Re: bumps in tyres
    Where is it ? sidewall ? tread ?
    If its in the sidewall chances are it will grow.
    Change tyre. Ideally you should change 4 tyres all at the same time on a 4x4 car, but if the others don't have much wear on them I'd just change the one.
    1,361
    Re: bumps in tyres
    Sounds like a form of blistering or rupture within the tyre, but I'm no expert and as Moff said get it to someone who knows.
    I would change it anyway whatever the outcome, because if it's a pocket of air it could blow out causing complete tyre failure.
    I can only see a reason to change one if the tyres are new, but also are they still covered under warranty?
