Sky InsuranceChris Nott
Results 1 to 16 of 16
    Oct 2003
    90
    Fitting a boost gauge
    Morning all!
    How difficult is it to fit a boost gauge? I want one! Any ideas where to fit the unit?
    Also does anyone know if this voids the Audi warranty?
    Cheers, [img]/ubbthreads/images/graemlins/hug.gif[/img]
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Re: Fitting a boost gauge
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    [ QUOTE ]
    Damo said:
    Morning all!
    [/ QUOTE ]
    Damo
    I got mine fitted by a garage because I didn't know what line to tap into for the boost gauge to run off of. I'll take some photos tonight to give you an idea of what you have to do.
    Grant
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    Fuel regulator hose..........very easy!
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    [ QUOTE ]
    [/ QUOTE ]
    Easy when you know which one you have to cut! No so easy if you were like me and didn't have a clue!
    Feb 2003
    Lincolnshire/Bournemouth
    739
    I wouldn't reccomend using the FPR hose. It's only slight, but there is a latency induced by tapping into the hose. That is the reason the hose is so short and direct to the FPR.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    I used WAK'S site as I did not know until then [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Where is yours tapped into Mark?
    Feb 2003
    739
    The DV hose mate [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Your's being a later car may have some additional vacuum lines you can tap into.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    What......the recirc pipe?
    Feb 2003
    739
    [ QUOTE ]
    [/ QUOTE ]
    Aiiiii
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    So many hoses [img]/ubbthreads/images/graemlins/cry.gif[/img] [img]/ubbthreads/images/graemlins/crazy.gif[/img] [img]/ubbthreads/images/graemlins/shocked2.gif[/img]
    Mines out at the moment as I had that warranty work done.........waiting for a while before it goes back in to see how healthy she is.
    Feb 2003
    739
    If you want a hand we can have a look next time I'm down.
    PaulS3's Avatar
    UK
    988
    Thats the Fuel pressure regulator (FPR) line.
    Jul 2003
    Essex
    358
    How does that work then?
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    Why does Excursion not recommend tapping off this line?
    Feb 2003
    739
    If you get a leak on the FPR line there is potential for det and engine damage.
