Sky InsuranceChris Nott
    Dark Knight
    Jul 2008
    936
    Arrow Stange Starting problem ?
    Hi all ,
    started the car today and took a a few more turns than normal then started from cold . Then started at work after work and did the same why would it be doing this ?
    Current Audi A3 2.0 TDI New shape
    Audi S3 -MAD / Tax Beater /Forge 007/Stage 2 Vagcheck /
    Mk2 G60 Stage 4 Jabbasport
    Corrado G60 Stage 4 Jabbasport / Porsche Rims / bhp 265/ decat
    jamieface's Avatar
    the only S3 in the villiage
    Oct 2007
    Cheltenhamshire
    198
    hey there i had the same problem with mine and it turned out to be the cam sensor/crank sensor, it can also be the temp sender unit too, your best bet is to see if anyone on here can doa scan with vagcom for you to try and narrowit down a little
    Dark Knight
    Jul 2008
    936
    Arrow testing
    Whats the best way to test i tryed my code reader and no codes where found ?
    Quote Originally Posted by jamieface View Post
    Dark Knight
    Jul 2008
    936
    anyone have what to check 1st ?
    Bellic's Avatar
    Dec 2006
    253
    i would try temp sensor first
    Dark Knight
    Jul 2008
    936
    Funny thing i had my cam gasket changed and only happened since then . I took the temp sensor of and cleaned and then started again in morning and was fine ??
