EM TuningJMB Retrofits
Results 1 to 8 of 8
    May 2008
    10
    99 1.8T keeps dying!
    Please help!
    Every time I stop at a set of lights or anything where I take my foot off the gas, my car just stalls, and the battery light comes on. It restarts fine, and continues until the next set of lights/junction.
    Any ideas?
    I'm thinking air filter. Any help would be great!?
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    that sounds air related to me...Maf?
    Turbo Sport, Auto (I know!), A lot of 's -and rising [latest add: Recon'd. tranny] sunk in her since Aug. 07...
    May 2008
    10
    Thats kind of what I'm thinking, although I'm hoping it is an air filter prob. This happens with the Mrs's Polo 6n, which has a general/common fault around the air filter/throttle body.
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    look for codes
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Bad MAF or air filter won't cause this. I would say you've got a problem with your throttle body or a bad vacuum leak. Most likely the former.
    Throttle switch to tell the ECU is in idle or WOT state is in there. Also stepper motor for idle stability is in there. Check the cable to it first, but as Clach says, you should see some error codes relating to the throttle body. If not, then it may be a vacuum leak, but that would usually cause a lumpy idle.
    Jun 2003
    World of my own
    9,813
    I had this on my A4 and eventually turned out to be the water pump stalling the engine as it was on its way to seizing up. Luckily it was leaking slightly so I got it changed because of that (as Audi didn't change it when they did the timing belt, tossers), and it cured the problem. When we removed it, it was so tight you could not turn it by hand at all. It's a long shot but worth considering if all the more likely causes don't sort it and it wasn't changed with the timing belt.
    Alex Turner
    May 2008
    10
    Forgot to mention, I've just changed the battery, as the old one wasn't holding a charge. Could this have anything to do with it? It was fine before, except for the battery not holding a charge for long.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Ahh, you might well need to perform a throttle re-alignment if you'd had the battery off. Especially if it was fine before.
    Performed, yes you've guessed it, through vag-com for DBW cars. Self aligning for non-DBW cars if you switch on the ignition and don't start the engine, don't touch the throttle pedal and wait for the sound from the throttle body to stop (about 20-30 seconds).
