Chris NottBadger5
Results 1 to 8 of 8
    Oct 2008
    11
    Audi S3 2002 Arm rest stuck
    Hello, My arm rest is stuck in the upright position, i hav eseen this happen on a couple of different S3's, does anyone know how to release it?
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    It's a common problem I'm afraid, components in the release mechanism break - Audi have something called an 'Armrest service kit' available which contains parts to replace the flimsy ones. That won't help you get it back to horizontal though, just stop it from happening again once you have...
    As far as I remember there are two options to return it to horizontal pending a fix - brute force (but you may make more damage in the process, so be careful), or removing it and taking it to bits...
    Defratos also has a 'home-brew' fix too: http://00626e1.netsolhost.com/formoshun/s3/Armrest.htm
    There's a reasonable amount of information on the board about it if you search for 'stuck armrest' in the 8L forum...
    Regards,
    Rob.
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
    Nov 2007
    158
    dont buy the service kit!! i had this and just read posts on here and its a easy fix with a screw and glue and its taken some abuse now and still great!!
    first get it in horizontal pos you can remove the washerd ect on the shaft and prise it down carefully then follow instruction on here for rest
    its really pretty simple
    27,126
    Has this got the push button release or ratchet system?
    Usually its the ratchet system thats stuck in position, need to remove from car & disassmeble the armrest to see if its just stuck or actually worn down/broken inside, I'm sure there was a repair kit for the 8L/B5 armrest when they did this.
    On my old S3 the ratchet system actually had worn down from when I rest my arm on & no I'm not fat, guess the metal was fairly soft, I was lucky to still be in warranty
    27,126
    Ah beaten to the post, way to go Rob.
    GT130's Avatar
    247
    Mine got stuck in the upright position the day before going on holiday, put an order in for the repair kit which was 13 quid and thought i'd have a quick play in the meantime to see if i could get it down - if you use a tiny screwdriver (type you would use on glasses etc) you can push the ratchet in whilst you push the handle in, you will feel one side unclick then just do the otherside - got mine down and have not bothered to replace the handle yet - HOW DO YOU GET THE INSIDE TRIM OFF - any easy way apart from stanley knife scrapping it off from a corner ??
    51 plate Audi S3 - Silver with Bose, Symphony 2, Armrest and of course Rs4's.....
    Ist Audi after 8 VW's in a line......
    Driven/borrowed through work..RS4 Wagon, Focus ST3, Golf R32, Astra VXR..
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    Quote Originally Posted by GT130 View Post
    Dont scrape the felt off, just feel very carefuly for the screw heads, once you locate them put your torx bit in the screw head and unscrew them, only the felt that covered the screw heads is then removed. You dont need to scrape any off, you can remove the screws with the felt intact
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    Staffordshire
    216
    i bought an s3 last week and it had this problem. im guessing mine is the push button type. there was a missing piece which must of been the button.
    i located the four hidden screws as described further up this page.
    i made my own button using the handle of a cutlery fork and its turned out ok lol...
    i'll try and upload the photos now......
    heres a link to the photos, they are in reverse order!
    molineux84's Album: A3 S3 jammed armrest fix
