Results 1 to 14 of 14
Thread: Wishbones
    Mar 2007
    Wishbones
    Car: A3 1.8T Quattro Sport 2001 (Y reg)
    Just got back from garage after getting an ABS sensor fixed and the mechanic said he took it for a quick run after fixing it and noticed I had some movement in my front wishbones. The car has been feeling quite skittish at speed (circa the national speed limit, maybe a touch over but not by a lot oh no no no) recently and hasn't been handling anywhere near as well.
    I have read a few posts here about wishbones and bushes and what not. My mechanic is quite happy for me to purchase the wishbones (only my OSF one seems to be skewed but he suggests getting both done at the same time...) and i imagine new bushes are required too (those S3 ones I've seen mentioned somewhere sound good {not polybush [whatever the f they are???]})?
    Just really after some info, cost of wishbones/bushes (finding it difficult to locate new prices, don't want used), whether there is a "preferred" brand or what, any extra info is good info. I'm afraid when it comes to cars I just like driving em, not fiddling with em.
    So, well, thanks any for info in advance.
    s3ollie's Avatar
    Jan 2007
    749
    its normally only the rear one that wears. thay are only a few quid. bit harder to change than the whole wishbone but a around 100 each side it makes no sence to me to change the whole lot just easier! these are the ones i got http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=130253521505
    8P S3
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Replace both at the same time, the front lower track arms should come with the bushes, and get a 4 wheel allignment/tracking done after.
    You've got to have a laugh!
    afcjay's Avatar
    Aug 2008
    426
    if i was you id go for originals VAG items.think they are around 51+ VAT per side for the wisbones or 18 for the bushes on there own per side
    while your at it,you might aswell do the ARB bushes,link arm,ball joints and tie rod ends
    from experience in the past,i would steer clear of aftermarket items such as GSF/Eurocarparts etc for the sake of a few quid
    3dr Dolphin Grey Audi A3 2.0 TDI S-Line
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Quote Originally Posted by afcjay View Post
    why?
    ^^ In my opinion
    afcjay's Avatar
    Aug 2008
    426
    Quote Originally Posted by abdus View Post
    why?
    bad/cheap quality and can cause other problems
    also they dont last 5 mins compared to original items
    complete waste of time and money if you ask me
    youll end up doing them 2-3 times at least compared to if you fit original items.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Steer clear of poly bushes. Fit the OEM rubber bush at the front of the wishbone, but use the solid rubber mount from the S3/TT for the rear of he wishbone.
    If you are feeling brave you could seam weld the wishbone for extra strength and rigidity. Some tuning companies offer seam welded items off the shelf.
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Yes fit genuine VAG wishbones. The alternatives simply dont last.
    2003 Audi S3 + Go faster bits
    Jul 2004
    Cambridge
    339
    I had problems with my wishbones too. I was getting annoying squeeking over bumps.
    A local independant garage said to replace both my wishbones.
    However, the dealer said to just replace the bushes. They push out the old ones and press the new ones in. Squeeking gone.
    So if your wishbones are fine, then you could just replaces the bushes. Most decent garages should be able to press them out.
    Work commute:
    Honda CBR 1000RR
    169 kg & 170 bhp - eeek!
    Backdraft Big Turbo Silver S3, Supersprint, Eibach lowered, QST rear tiebars, SPA boost gauge Sold
    Lotus Elise 111R also Sold
    Wanted: Honda powered Lotus Elise S2
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Have you had one that has failed, rusted through or other?
    Remember the S3/TT wishbones are cast. 1.8T wishbones are pressed and welded.
    s3ollie's Avatar
    Jan 2007
    749
    for most parts, yes im with you but c'mon its a rubber bush
    8P S3
    afcjay's Avatar
    Aug 2008
    426
    its not just the bushes im referring to.
    the quality and strengh of the metal they use for the wishbones themselves is poor quality.
    you want wishbones to be as strong as possible hence people get them seam welded for extra strengh
    vag original items are of a good quality and are built to last not some flimsy wishbone poor quality item knocked up in Timbucktoo
    buying non vag items is false economy if you ask me but its your choice at the end of the day
    youll buy at least 2 in the time a original will last and if your paying to have them fitted,thats 2 lots of fitting costs as well as the wisbones themselves.
    you can buy the bushes for around 18 notes per side from Audi/vag and press the old ones out which is a cheaper alternative as long as the original wishbone itself is ok.
    s3ollie's Avatar
    Jan 2007
    749
    and the best bit is you can do it on a vice using a couple of large sockets, no press needed
    8P S3
    Mar 2007
    Thanks all for your help, I know what I'm after now and hope to get it done this week.
