Chris NottMonster Motorsport
Results 1 to 10 of 10
Thread: engine errors
    Jun 2008
    Edinburgh
    80
    engine errors
    Ran vag-com with cheapy ebay lead (cannae afford the proper ross tech one but suitably impressed enough to put it on my wish list!) and got the following:
    Address 01: Engine
    Controller: 06A 906 032 BJ
    Component: 1.8L R4/5VT 0002
    Coding: 10710
    Shop #: WSC 06435
    WAUZZZ8LZ1A113700 AUZ7Z0A1809399
    2 Faults Found:
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    17545 - Shareware Version. To Decode all DTCs
    P1137 - 35-10 - Please Register/Activate - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes
    Controller: 1C0 907 379 F
    Component: ESP ALLRAD MK60 0104
    Coding: 0023046
    Shop #: WSC 06435
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    003 - Mechanical Failure
    Do I need a new bleed/dump valve?
    I have wondered on occasion if something wasn't right with turbo cos sometimes felt it was down on power. Most of the time it seems fine tho.
    Can't find anything that tells me what the second code is for.
    I'm thinking the steering angle sensor is the reason the traction control light is permanently on. Is that an easy/cheap replacement?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Take a look on Ross Wiki in the fault codes section for a starting place
    Can't say about the steering angle sensor as I've not had to deal with that problem before.
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    The first sounds like the good old Bosch Divertor Valve, a new'un will set you back about 25 but you'd be better going for an after market piston type, such as the Forge or Turbosmart for around 90 squids as the Bpsch ones don't last long.
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    Jun 2008
    Edinburgh
    80
    The wiki says that other fault is
    17545/P1137/004407 - Fuel Trim: Bank 1 (Add): System too Rich
    Possible Symptoms
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Mass Air Flow (MAF) Sensor faulty
    • Fuel Pressure Regulator faulty
    • Fuel Injector(s) faulty
    • Oxygen Sensor Control faulty
      • Oxygen Sensor(s) faulty
    • Evaporative Emission (EVAP) System faulty
    Engine light was on for a wee bit but disappeared again. Then it does say intermittant.That steering angle sensor just sounds weird!
    Jun 2008
    Edinburgh
    80
    My traction control is back. Never even did anything.
    This car is weird. I guess audi's can fix some mechanical failures themselves!
    Is this the kind of thing I should be looking at?
    http://www.carperformancepartsuk.com...ter-Valve.html
    Is there much of a difference between fast road/normal one?
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    That's the honey, not sure about the fast/normal question. The forge has interchangeable springs for varying turbo pressures and the turbosmart is adjustable by tightening the tension on the spring
    Jun 2008
    Edinburgh
    80
    Think I've found the potential problem with the MAF
    jesters3's Avatar
    The Shire's
    1,516
    On the 17705 issue I had it came down to a split in an oil breather hose, replaced and the fault went.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    S3 Paul's Avatar
    Oct 2006
    2,764
    Stearing angle sensor....
    I remember that one !
    Right, Best i remember its normaly down the the cars tracking... basicaly the stearing wheel/collumn isnt fully in line with the wheels. Mine used to come and go with faster driving on the motorway being the main trigger. This i was told was down to the fact there is either... all 4 wheels doing same speed but steering wheel not being 100% straight. or the steering wheel being straight but the speed sensors (abs sensors) reading diffrent speeds. After turning the ignition off it normaly goes... only to come back later the same day. Have the car tracked propperly and ask if you can sit in the car and hold the steering wheel BANG SQUARE , I would be shocked if that didnt sort that one...
    The other fault is a bit of a grey area... people have the same fault but with diffrent problems... It could be the DV valve. it could be a split breather pipe or any of either the vacum or boost pipes... start with the breather pipes. Then ask to borrow some ones none faulty stock DV. most people have after market ones so somebody will have a spare.
    Hope this helps.
    Noggy Blue 2001 S3
    Jun 2008
    Edinburgh
    80
    Quote Originally Posted by S3 Paul View Post
    Pretty much the same here. Will get it checked at service.
