AH FabricationsChris Nott
Results 1 to 10 of 10
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Replacing the top mounts
    Guys, not sure if you remember or not, but a while ago i posted up saying i was getting a creaking noise when going over bumps from the front of the car, initially it was diagnosed at the ARB Bushes, which i have since changed, but the noise is still there.
    I remember Sandip on the forum saying that he had changed his top mounts and this got rid of the noise on his, so im going to give this a go, but just wanted to know what was involved.
    **Is it a big job?
    **Do i need to take the whole suspension leg out, or can it be done from the engine bay?
    **How long will it take to do?
    Any help and advice would be much appreciated.
    Thanks in advance
    Nilz
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Its a straightforward job just a little time consuming.
    You need to remove the whole shock from the car and remove the spring, replace the topmount and topmount bearing, put back together and refit.
    I'd say your looking at an hour a side tops if you do it at at a relaxed pace.
    There are a quite few tools involved including : Spring compressors, hub splitter (optional), 7mm long allen key (brake caliper one from halfords works well) and deep 21mm socket and 18mm socket.
    Easy job if your ok with a spanner.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    This is for a bora, but he front end is the same for your car.
    http://nclh.org/car/coilover_howto/
    Nilz's Avatar
    Apr 2006
    10,087
    You know once it has been done, does the car need the tracking done, as I am removing the suspension leg, or is that only if the car is being lowered??
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    You should get it setup, but it's up to you.
    Before pulling it all apart, deffo get them checked for play.
    Nilz's Avatar
    Apr 2006
    10,087
    Okie dokes, and soz for all the questions, whats this I hear about 4 wheel alignment, will i have to get all four wheels done, or just the front two??
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    if your just doing the top mount i wouldn`t bother with alignment as it should be ok.
    red to red black to black blue to bits
    bouncer--daz's Avatar
    A dog is for life....not just for friday nights!
    Mar 2007
    Gloucestershire
    543
    Yer i did mine when I put the new kit on.... was definately worth doing and the cost of the rubber mount and bearings are sod all even from a dealer. Might be worth gettin a garage to do it though forthe amount of work. Its alot easier when u have a ramp and for 20 for an hours work its worth it.
    Daz - Audi A3 - 18" rs4 alloys - Weitec ultra gt 30mm kit - pipercross panel filter - tints all round - facelight rear lights - clear side repeaters - german style plates - flip out dvd touchscreen hu
    Nilz's Avatar
    Apr 2006
    10,087
    Okie dokes, might go down that route then....
    Daz where you been hiding??
    Aint seen you on here for ages
    Jul 2004
    Cambridge
    339
    Btw, have you considered that it may be the bushes in the wishbones?
    I had squeaking noises going over bumps, and I too was told it was the arb bushes. However, on further inspection, it turned out that I had worn wishbone bushes.
    Dealer replaced both sides for 380. Squeaking gone.
    Work commute:
    Honda CBR 1000RR
    169 kg & 170 bhp - eeek!
    Backdraft Big Turbo Silver S3, Supersprint, Eibach lowered, QST rear tiebars, SPA boost gauge Sold
    Lotus Elise 111R also Sold
    Wanted: Honda powered Lotus Elise S2
