Sky InsuranceChris Nott
    Rai
    Apr 2003
    17
    Help needed - rear R32 19mm ARB for S3/TT
    Hoping someone can help me. I've got a Quattro TT which is basically the same as the setup on the S3. I believe AmD Tuning offer this upgrade over the there in the UK....
    I'm looking at ordering the rear R32 19mm Anti-roll-bar with rubber u-bolt mounts from Volkswagen (am stuck here in Australia otherwise this would all be easy!). I need to know will this definitely all bolt on directly to the control arm ends and U-bolts on the S3 or do I need to pay attention to anything in particular? Any part #s you could provide also would be great since Volkswagen Germany said this will be a once off order with no-return policy.
    Appreciated. [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Jul 2003
    200
    Re: Help needed - rear R32 19mm ARB for S3/TT
    mate i m from New Zealand, i can help you out, i m getting 3 extra bars coming in, PM me
    by the way yes direct bolt on
