AH FabricationsBadger5
Results 1 to 9 of 9
    May 2004
    14
    Aftermarket Bose Upgrade
    Hi All,
    My A3 currently has a standard Audio setup, which is OK I suppose.
    Is it possible, if I take my car to Audi to upgrade to a Bose system with the Sub; how much is it? Is it worth it?
    I don't fancy fitting one myself ripping out all one side of the car to wiring it up to the HU.
    Nov 2003
    At Home
    89
    Re: Aftermarket Bose Upgrade
    If you search for Bose you'll find it's been discussed before, just a few times!
    I think it'll be fair to say that the majority of people prefer an aftermarket system to the Bose.
    robthehungrymonkey's Avatar
    Apr 2004
    Uckfield, Near Brighton
    555
    I have the BOSE system in my car, and although it seems fine, and I'm not going to upgrade it, I still think that you are way better off going for an aftermarket set up. In my previous car, I had a fairly good head unit and just a decent pair of 6 X 9's, but I still think it was better than the BOSE. Much cheaper, and likely to be beter in every way.
    Oct 2003
    South Wales
    2,942
    Even the non-Bose setup has a sub in the boot!
    I would say from reading the above that you son't have Bose.
    Rich.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,570
    The Bose sub has two speakers and the non has one
    There are "BOSE" badges on the front speaker grills too
    Jun 2003
    World of my own
    9,813
    And a Bose logo on the 2 speaker sub
    Mar 2003
    153
    The 2001 model I had with Bose didn't have the logos either...
    Oct 2003
    South Wales
    2,942
    Mines a 20001 model and it has the logo's..
    MarkyB's Avatar
    Bristol & Salisbury
    106
    MY01, BOSE Speakers with logos on the speaker grills and the "BOSE" message on the Concert HU when it's first switched on.
    BOSE is OK (better than stock), but you really are better of with an aftermarket solution which will be cheaper to purchase and install, sound better and if done carefully could be transplanted into your next car.
    If you'd prefer to keep the Audi Headunit (and deter would-be theives by keeping the "Stock" appearance?), you may be able fit an aftermarket Multichannel Power-Amp and speakers that are fed from the "Line Out" on the Audi Headunit.
    It's a compromise that the purists will wrinkle their noses at, but worth considering. You have the option of replacing the Audi Headunit with an aftermarket one at a later date if you are unhappy with it.
    One of my pet-projects is to replace the BOSE Speakers and Amp in my car with Pioneer kit and an AndyMac-SuperSub(TM) - keeping the Audi Headunit - when time & finances permit.
    Mark.
