Sky InsuranceChris Nott
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,563
    Removing rear S3 bumper
    1. How easy is it to remove the rear bumper?
    2. How do you remove it?
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Re: Removing rear S3 bumper
    [ QUOTE ]
    [/ QUOTE ]
    1. Piece of [img]/ubbthreads/images/graemlins/[censored].gif[/img]
    2. Jack car up, remove rear wheels. Remove screws (hex bolts) from around the lip if the arch/bumper. Open the boot, remove screws in the side of the channel (against the tail lights). Lift up the flap, and remove the screws from under there. Under the bumper, there should be a couple...remove them. peel the edge of the bumper away from the arch on each side, then slide off. Simple! [img]/ubbthreads/images/graemlins/grin.gif[/img]
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,563
    Cheers Rich.......will give it a go at the weekend [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Need to order a dog and bone mount off you too!
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    No problem.
    Give Jason a call before 12 if you like. to sort it out.
    Rich
