Chris NottAH Fabrications
    Mar 2008
    Swansea
    16
    Pulsing Interior Lights
    Recently i have noticed that intermittently my interior lights front/back are pulsing on/off under normal driving, i also have an issue that when i lock my car sometimes i turn back to notice the indicators flashing as if the alarm is going off but with no siren which i presume maybe related to the first problem.
    I have also noticed a ticking noice coming from somewhere behind the dashboard whcih sounds like a relay sticking possibly?
    any ideas please guys?
    cheers
    Dark Knight
    Jul 2008
    936
    intermittently my interior lights front/back are pulsing on/off ,
    sounds like a electrical fault a ground maybe shorting out had a problem like that with my mk2 golf gti .
    Current Audi A3 2.0 TDI New shape
    Audi S3 -MAD / Tax Beater /Forge 007/Stage 2 Vagcheck /
    Mk2 G60 Stage 4 Jabbasport
    Corrado G60 Stage 4 Jabbasport / Porsche Rims / bhp 265/ decat
    Carpy25's Avatar
    Oct 2007
    272
    had the same problem , plus random false alarms , mine was a sticking micro switch in the door lock ,this is what turns on the lights and triggers the alarm , the funny flash when you lock the car is telling you it thinks the doors still open ,if i opened and slamed the door hard it would stop but since sprayed it with wd40 and at seems ok at the moment
    Rob
    S3 Paul's Avatar
    Oct 2006
    2,759
    Same here. Its the pin switch inside the door lock/catch. you can tell its going to happen when the red light on the enge of the door stays on once the door has been closed. ive been told that you can either adjust the catch or replace the catch itself. I poked mine with a screwdriver and it has worked for now...
    Noggy Blue 2001 S3
