EM TuningChris Nott
Results 1 to 33 of 33
    S3-Andy's Avatar
    Apr 2008
    198
    Huge missfire under boost
    well guys as the title says my s3 has developed a huge missfire,
    the car drove fine to work this morning,no problems at all,however this evening on the way home as i entered a dual cariage way i put my foot down for a bit of go, it reved to about 2500 revs just as it was coming on boost i got a huge missfire/splutter,changed up and got the same in all gears all between 2-3000 revs.
    Going to have a proper look tommorow after work,i am going to start with plugs and coils as i have spares,i had a quick listen and can hear any boost leaks,
    the car revs and runs fine when parked up its only happening under boost, if it was a coil would the car no run lumpy?
    there is no management light, anyone experienced a similar problem or have any advice?
    would the maf or injector or any fuel issue bring the management light on?
    the car is a 2001 and has a revo map
    cheers for any help
    andy
    Tastyterrier's Avatar
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    Could well be the MAF, try running for a short while (like a mile or so) with it unplugged.
    A3 1.8TQS: Supersport Springs and Shocks, Xenons, BMC Filter, 18" OEM TTV6's, Bailey DV, N75J and Phase 1 Custom Code.
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    Sounds like a dying coil pack to me. Does the car drive ok if you stay off boost?
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    DBXdarkangel's Avatar
    Mar 2008
    Torquay
    161
    mine did the exact same thing. turns out it was the hose that goes from the turbo to the intercooler (near the front drivers inner wheel arch) i tightened it up and all was well. soon as hit 3k revs when the turbo kicked in, the pressure was lost and the car felt like i was breaking and miss fired real bad.
    A3 Turbo Problem?
    Audi A3 1.8 Turbo: Custom Code Stage 1, Full Custom Built 3 Inch Stainless Steel Exhaust, RS4 Alloys, Weitec 40mm Ultra GT Springs & Shocks.
    S3-Andy's Avatar
    Apr 2008
    198
    ill give all hoses a proper check tomorrow and yes the car seems fine when not on boost which does give the impression it could be boost related or prehaps the coils are just made to work harder when on boost?
    Mar 2008
    Torquay
    161
    Quote Originally Posted by S3-Andy View Post
    took me hours to check all hoses on mine properly. id check teh intercooler one i mentioned first. might save ya time m8ty. because the juberlee clip was near the wheel arch. it started rusting and for some reason worked loose with the water.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    I reckon it's a coil pack, the symptoms are the same as when two of mine went pop.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    S3-Andy's Avatar
    Apr 2008
    198
    i think thats gonna be first on the list
    got a spare new set when i bought the car
    cheers
    fran-s3's Avatar
    1,090
    Just to throw another cat in the pigeons, my did exactly the same thing.. I had multiple missfires come up on boost and my exhaust was even popping. Turned out it was my fuel pump! Obv wasn't getting enough fuel when it really needed it most... But yeah VAG-COM will be a big help, get someone to log your run.
    tel
    tel's Avatar
    4x4 junkie
    Oct 2007
    bedfont west london
    mine was doing this after my remap it was my plugs at fault
    S3-Andy's Avatar
    Apr 2008
    198
    just thought i would give a quick up date,
    drove the car to work this morning and found it still mis behaving in the same way although if you eased on the power gently it seemed fine,anyway i changed the 4 coil packs during my 30 min dinner break and glad to say it is a 100% improvement,only drove a few mile home but seemed to be responding and picking up very well,so it looks like problem solved,thanks to every one for their input
    the car has only done 43k but has a revo map is this a common fault should i expect to replace them anytime again?
    just glad the previous owner gave me a new set when i purchased the car 6 month ago
    thanks again
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    I remapped mine at 42k and it nobled the plugs with a month, that was 18 months ago now and it's been fine since. Which revision coilpack did you replace the knackered ones with? If it was the latest one (they have a letter at the end of the part code, I think the latest is J or R but can't remember exactly) then you should be fine.
    > S3 225 (03) - OEM+
    View: My S3 diary
    S3-Andy's Avatar
    Apr 2008
    198
    it had new plugs less than 3k ago,
    not sure about the code could be L i think, dont know when they were bought but at least i never had to shell out for them so i cant complain.
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    Can someone link to me to some plugs I can try in my S3? Garage did some pressure tests and fuel pump etc is still fine.. Wouldn't mind try to change the coilpacks myself to see if I can save a trip to JBS in Chesterfield.
    Is it any easy fix?
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Monkey Trainer
    Jul 2003
    Staffordshire
    341
    I have Bosch Super 4s in mine, they seem to work really well with the remap.
    Changing them is a sinch. Remove engine cover, pull the coil packs vertically upwards, take the spark plugs out of the cylinder head with a torque wrench with an extension arm and Spark Plug adaptor, refit new plugs (careful not to cross the thread), torque up the setting quoted on the plug and push the new coil pack down onto the spark plug until it clicks (should only need medium force).
    tel
    tel's Avatar
    4x4 junkie
    Oct 2007
    bedfont west london
    after loads of looking i went for bkr7e with a .28 gap which is a stage cooler
    they say every 50bhp over standard you go you need 1 stage cooler plug
    they sorted my running out and gave me better mileage
    super 4s were the plugs i had fitted that were giving me all my problems
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    so what are we concluding here, that Audi plugs will do the trick when remapped?
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    I'm yet to get my car back from the spray shop, but can someone send me a link to some plugs!? The plugs that tel talks about if poss... I want to try as much as I can at home, before sendind the car in to a 'local' specialist.. (!)
    would it be worth me letting Audi takeWmy car from the Sprayshop to do a VAGCOM run on it? Any idea how much they'd charge? (I'd like to find someone off here local too me if preferable, pay them rather than Audi - Newark, Nottinghamshire)
    Aug 2009
    hi my a3 2.0 tdi is doin this was fine yesterday then put sum deisel in and it started splutterin between 2 & 3 thou revs dont now if the fuel has got sum crap init or summat anyone any ideas ??? thanks
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Visit s3 Hoggy's Instagram Channel
    Hi lee you might get a better responce if you post in the 8p or diesel section mate
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    Aug 2009
    Quote Originally Posted by s3 Hoggy View Post
    cheers hoggy can u tell me ow 2 do this i i only joined 2day and cant find where 2 go
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,637
    Yes mate if you click home in the top left corner. You will then be at the main home screen where you will find forums for; diesels, and a forum for new a3's then just hit new thread and ur away!
    2002 S3 REVO
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    yes, there are higher cylinder pressures when under boost and a weak spark will literally blow out. wider gaps on worn plugs also will exasserbate the work the coil energy which needs to be produced to arc, and weak ones will do this.
    best to swap all 4 as they need to be matched and fresh in energy terms.. you would be surprised how much a difference to burn effeciency some weak coils will cause.
    surprised me on matts a3 BT build.. completely changed the afr it was running from ok to lean as when swapped to 4 new coils and plugs.
    regards
    bill
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Apr 2009
    100
    i am suffering exactly the same problem at the moment, just had a remap and the car is now misfiring badly, the chap said it is almost certainly the coil packs, does anyone know the best place to get them, or is it a main dealer visit ? also, does anyone know how much they are at audi?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    25 approx each + vat
    GSF car parts, or your local TPS
    bill@badger5.co.uk
    Apr 2009
    100
    thanks Badger, who are TPS ?
  28. #27
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
  29. #28
    Apr 2009
    100
    thanks Andrew, i'll look into them
  30. #29
    IIIadidasboy's Avatar
    Jun 2009
    Kent
    311
    Can't belive just how many of us are suffering from misfires at the moment - must be something in the air!!!!
    I can see a swell in coil pack / MAF sales coming up!!
    2003 ARY A3 TQS - totally bog except for 18" Dezent Motion Blacks - Hopefully the Brembo Jr will fit these and I can start to update my sig!!
  31. #30
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    TPS = Trade Parts (aka VW/Audi group)
    bill@badger5.co.uk
  32. #31
    Apr 2009
    100
    cheers badger !
  33. #32
    subby's Avatar
    May 2009
    128
    Ive just put Denso Iridium Tough Spark Plug VK20Y in mine.
    Had it remapped today and they seem fine.
    1996 JDM Celica GT Four
  34. #33
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    Denso Iridiums are not a plug I will ever use again.
    ceramics cracked on 3 out of 4 of mine, damaging pistons and turbo.
    to repair for 30 of plugs.
    NGKs for me now
    bill@badger5.co.uk
