    Sep 2008
    Oxfordshire
    Newbie Q - Need some help advice - Misfire
    Hello all.
    I am a newbie to the forums, so please go gentle.
    I recently purchased a modified 1.8T Sport off a Forum member. Nice car although it seems to misfire / jolt either when coming off load / changing gear especially between 2500 - 3500 rpm. It also does not seem to be around the 240bhp figure that the last remap took it too.
    Having searched the forums i see a misfire / underpower can be due to coil packs / Air leaks. There doesnt seem to be any splits in the rubber or silicone so im ruling out air leaks, is there anything else that can be causing this problem.
    I put in new plugs, but this has not made a difference. Ive ordered a VAGCOM but when it arrives i wont really know what i will be looking for to assist my diagnosis. If anyone can suggest or offer help on how to go about fixing this problem i will be most grateful
    James
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Welcome to the forum James,
    Have a look through the vag.com owners sticky at the top of the forum, there may be a member near to you who can help until your vag.com arrives.
    When it does arrive, you can run a full scan (engine, brakes etc) and it'll come up with any fault codes it finds
    Hope you get it sorted
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    Revo
    Aug 2004
    Southwest
    98
    What year is the car?
    If it is 2001 then coil packs could be 1st choice but like Mike A3 says VAG-COM will help
    Sep 2008
    Oxfordshire
    Thanks guys. Well hopefully VAGCOM arrives soon. Typically i now have a ABS problem as well. These things all seem to com together! Will post again once i get my head around VAGCOM.
    JT
    S3-Andy's Avatar
    Apr 2008
    198
    i would say coil packs mate, just done mine today,and now u mention it mine was a little hesitant when changing,getting on and off the throttle at that rpm range
    jimbobery's Avatar
    S3
    May 2008
    257
    I have a word doc that details how to log some stuff in vagcom that might help. PM me your email add
