Chris NottBadger5
Results 1 to 8 of 8
    jays3's Avatar
    Jul 2008
    75
    brake pad warning light
    i had this light come on earlier this week so i just replaced the pads and obveously the sensor, the light hasnt gone out, any ideas,
    Jan 2007
    Hampshire
    1,155
    All connected correctly? No broken or damaged wires?
    A6 3.0 TDI.
    jays3's Avatar
    Jul 2008
    75
    no everything looks fine, would disconnecting the battery for an hour reset it.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,096
    Doubt that will reset it, best thing to do is get it on vagcom...
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    It's just a loop of wire, something's knackered between the connector and the pad if the lights still on!
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    As above, wire will be split
    Black S3
    jesters3's Avatar
    The Shire's
    1,516
    Make sure the connector is clicked in. My warning stayed on because I hadn't done this.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    Quote Originally Posted by jesters3 View Post
    yep, had the same problem
    ^^ In my opinion
