Monster MotorsportEM Tuning
Results 1 to 10 of 10
    Feb 2007
    UK
    229
    Running temp fluctuation.
    Recently i noticed the temp would suddenly drop from 90 on the dial to around 80 - 85, noticed it most when on the motorway driving at a constant speed....
    Instantly thought thermostat !
    Tonight i got the temp up on disp #49 on the Air-con diagnostic display. For most of my journey the temp didnt go above 80 deg (dial a fraction under 90), so still thinking thermostat...... untill i pulled up and it crept upto 90 on the diagnostic disp, but kept going to 102 untill the fan kicked in and bought it back down to around 90 ish, though all the time the dial was bang on 90, even tho it apparently hit 102....
    a) I thought the fan should come in way before 102. so could this just be a faulty temp sender reading HI?, or even a faulty fan switch?
    b) Why does it stay down at 80 when drivng, either thermostat is sticking or the temp sender is reading LOW?
    Any ideas please.
    Might just change both the Thermostat and Temp Sender.!?
    James
    Feb 2007
    UK
    229
    The more i think about it, i think it is the thermostat.
    I would imagine a fan switch would come in somewhere around 100 ??
    Therfore the sender is correct.
    jimbobery's Avatar
    S3
    May 2008
    257
    Hi. I had a temperature fluctuation problem which turned out to be thermostat. Now it goes up to 90 and never moves. When I was looking into this I think I read that the fan does kick in around 100 and then switches off around 95.
    Its not too expensive to change both thermostat and temp sender. Thermostat is a bit of a pain as one of the bolts is a bit tricky to get at but with the right tools its not too bad. There is a fair few post about thermostat change on here and a guide.
    There is also a guide for the temp sender on http://www.wak-tt.com/ (I think)
    Clach's Avatar
    A3 - 1.8Ts
    Jul 2007
    Oxford
    974
    well done soame probs on mine. Although it has not fluctuated for a while now!!
    Turbo Sport, Auto (I know!), A lot of 's -and rising [latest add: Recon'd. tranny] sunk in her since Aug. 07...
    Feb 2007
    UK
    229
    Replaced the thermostat today, all seems to be sorted now! Will keep an eye on it for a while tho!
    James
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    where is the thermostat on these? picking up the sender tomorrow....
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    actually cancel that, ive just searched the previous posts and found a fitting guide....what an arse of a job!!
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    Quote Originally Posted by 1animal1 View Post
    Certainly looks it if you don't have the right tools. I got mine changed at the same time as my clutch as it looked a bit too fiddly for my liking!
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    Feb 2007
    UK
    229
    Not the easiest of jobs, prob took me an hour in total. Not too hard just fiddly. I removed the wires from the alternator to give more access too.
    The most important tool is a 3/8" set of extentions and a UJ adaptor to get to the bottom bolt!!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    my worst worry is emptying the coolant.... replaced on my first car and didnt prime it correctly, almost ended up over heating..... last time i touch a coolant system
    apart from the sender unit which is a doddle to fit
