EM TuningBadger5
Thread: Hoses
    Jun 2003
    133
    Hoses
    Hi
    Anyone had problems with the hose in the picture splitting or slipping off. I have put a jubilee clip on it but it still manages to work its way off. I will get a new one tomorrow.
    Anyone know if samco does one of these hoses?
    Jun 2003
    133
    Re: Hoses
    From different angle
    PaulRS3's Avatar
    UK
    1,005
    Re: Hoses
    That is a crank case vent , PCV (positive crankcase vent???)IIRC
    Maybe that something else is afoot if it is blowing off?
    Having said that, i have replaced my major jubilees (but not that one) with JCS marine grade stainless steel Hi-Grip ones. As the OEM ones are just crap.
    one tip is clean the hose tail comming out the engine, and inside of the hose with electrical solvent cleaner, meths or petrol, anything you have to hand to get rid of any oily residue, as that makes them super slipery and easy blow off if there is any left.
    Jun 2003
    133
    Re: Hoses
    Cheers for the reply paul, I have been having a problem with the car recently but i think i have rectifyed that by replacing the OEM clip at the other end of that hose (the one connected to the mushroom shape thing, dont know the name of it [img]/ubbthreads/images/graemlins/frown.gif[/img] ) with a jubilee clip, it was leaking. Since i replaced that its the other end that has started to work its way off.
    Think i'll pop down the Audi garage tomorrow see what they say.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Re: Hoses
    That's induction side so should be negative pressure if anything, even if the crankcase breather was blowing the suction from the intake should compensate for this. I recon it's a dodgy jubilee clip.
    May 2004
    14
    Re: Hoses
    What are the symptons of a hose that has blown off or leaking? I am not making requested boost - could a hose leak or blown hose be the cause?
