Sky InsuranceEM Tuning
Results 1 to 9 of 9
    afcjay's Avatar
    Aug 2008
    426
    electrical problems (mirrors and interior lights)
    can anyone help
    both my eletric mirrors wont adjust and the lights behind the sun blinds dont work.
    checked the lamps for the lamps and they are fine
    does anyone have any ideas
    anyone know the fuse numbers etc i should check etc?
    3dr Dolphin Grey Audi A3 2.0 TDI S-Line
    afcjay's Avatar
    Aug 2008
    426
    can anyone help?
    Ibzzzzz's Avatar
    Apr 2007
    666
    Go into your handbook and find the page with the fuses listed use that to identify the numbers of the fuses you sould be replacing. IIRC the lights in the visors only light up when you got the mirror open.
    2006 - A4 - 1997 1.8T 20VS, Full Black Recaro Leathers, Concert, Climate Control, Facelifted, Remus, Front armrest! - Sold
    2007 - A3 20vs -bridge gap motor....
    2008 - Think its time for the Civic Type R.
    2009 - Screw a Type R. Got a VR6 instead (missed even now)
    2011 - Focus St170. < what was i thinking...
    2012 - Lateee 8L S3 with EVERY extra....Broken...other asn members enjoying my parts!
    NOW! - B5 S4 Avant - 2.7 Twin Turbo POWWEERR! WWOOOOOSSSHHH!
    afcjay's Avatar
    Aug 2008
    426
    think im oing to have to invest in a haynes manual to be honest as i cant find my owners manual.
    i took the fuse cover off and checked all the fuses in there.normally all the imfo is on the cover itself
    i cant work out the visor lights as all the other interior lights work ok eg glovebox,boot and normal interior lights? would have thought they would all be on the same circuit?
    as for the mirrors,as they both dont work im thinking it must be a fuse.
    there are some spare spaces for fuses so like i say,think ill have to get a haynes manual.always handy to have anyway
    thanks
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Haynes may help, but dont know if you know anyone in the area that has a handbook they may be able to borrow you or just look at if you go to theirs or they come to yours with it...just an idea...Im at work at the mo, otherwise I would have had a look in mine for you.
    Ibzzzzz's Avatar
    Apr 2007
    666
    Where abouts in london are you mate? I could possibly help you out!
    afcjay's Avatar
    Aug 2008
    426
    Quote Originally Posted by Ibzzzzz View Post
    found the manaul just now so will take a look tomorrow and hopefully get it sorted.
    afcjay's Avatar
    Aug 2008
    426
    cant work it out,the fuses seem ok but noticed the mirror adjuster switch does not light up so obiously,i have no power getting to it?
    ill have to take the switch out and check the connection etc
    as for the mirror lights,ive got no idea unless they are fed by the same supply as the mirrors?
    anyone got any suggestions?
    afcjay's Avatar
    Aug 2008
    426
    turns out it was one of the mini fuses (no.5) operates the mirrors and the lights in the sun visors.
    i did a quick visual check on all the fusese before and all seemeed to be ok but didnt fancy taking the door card off so thought id take it out,clean it and close the contact up a little as it was slightly loose.
    turns out,it did the job.all sorted
