AVUSSILVER
hi
im so peed off its unbeleivable , i always wanted the little woosh noise but knew the s3 engines cant use them so i never botherd getting a blow off valave, then forge come up with the splitr valave that diverts the air but also releases 30 % to atmosphere,
well i had it on for a couple of days no problems then after trying to boot it at the lights i suddenly lost power and felt like there was no boost ,, car just wasnt picking up speed the way it used to,,, so i was just waiting for the engine light to come on which after 30 mins it did.
car was running fine before i changed the dv
im thinkiing to just put the blanking plate of the dv valve and make it just recirculating
has any one else experienced this problem ??
thanks
thanks
