EM TuningJMB Retrofits
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 149
  1. #41
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    thanks Sits..... ive been looking at a few on fleabay around the same size...... how easy would it be to run pipes between the existing SMICS, fitting one of these between (keeping the fogs)
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
  3. #42
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    This has been bugging me for such a long time I finally got around to taking the bumper off my car today.
    I don't reckon this one has any hope of fitting without serious buggering around!
    Quote Originally Posted by s3_kev View Post
    thats the whole cooler, i did a serch on here and found this to be the size most people use when doing there custom made, im pretty sure the inlet and outlets are 76mm to forgot to put the link to where im getting it from opps here we go http://www.amber-performance.co.uk/info.php?i=278
    I took some pics and did some measuring I thought was worth sharing, however I've realised I should have done even more now. I want to keep the fog lights and generally make it look totally oem so was just measuring the space in front of the air con radiator.
    I reckon you could fit a 56cm wide, 36cm tall and 60mm deep intercooler in without any cutting at all. Or a 47.5cm wide, same height and 70mm deep that's total space available.
    The standard ones cores are 17cm x 19cm x 85mm which was actually larger than I thought they would be.
    Loads more here:
    http://s4.photobucket.com/albums/y12...s/Intercooler/
  4. #43
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    Someones been a busy boy!! I suppose the hunt is on for a universal FMIC within your dimensions, I'll have a nose around see if i can find one!
  5. #44
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    Slightly to small
    Slightly too big
    Maybe fit with a tiny bit of trimming
    I think that cutting will be required otherwise cooler will just be too small.
    It's good to get everyone's ideas on here, as we all know the S3 FMIC's are a rip off and if we come across a good set up our selves I'm sure quite a few will be interested!
    anyone else got any ideas or found a cooler? or comments on which of the above might be best?
  6. #45
    sitrials's Avatar
    Mar 2007
    Stamford, Lincs
    866
    try the intercoolerking on ebay that where i got mine 450x230x65 you can also get 450x300x76 from someone else to keep the fogs use 51mm pipe work instead of 63/76mm
    S3 - Gone but not forgotten!
  7. #46
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    dont think from looking at those pics that it will be easy keeping the SMIC's lol, damn fine work taking those pics.....
    my thoughts are (which ithink ev1 else is at) that you need one big enough to make it worth replacing the SMIC's which dont look small
  8. #47
    Jun 2004
    Crowthorne, England
    2,512
    I'm going to have another look (as soon as I get time) at what's available, Bell intercoolers do a core that's the right size but again I'm guessing after fitting end tanks etc. it'll get pricey. There are some on ebay that might be worth a look and if you could space the mount of the crash bar forward slightly (which I believe someone on here had done) then it might mean fitting a 76mm deep ~ 450 wide core would be pretty straight forward.
    I'm probably going to take everything apart again and either buy one of the cheap ones and see how it fits or make up some out of card / wood to see what will really fit and how.
    It's not hard to get an intercooler thats got a bigger surface area than the SMICs but it depends how much volume you want to increase, If you could get something that filled the 56cm wide, 36cm tall and 60mm deep space it's over twice the volume of the two side mounts!
  9. #48
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by god_thats_quick View Post
    Loads more here:
    well my intercooler arrived this morning, and spent my lunch hour fitting it to the car and its all up and fits lovely just need to raise the hight a little to fit the pipe work in where the two side grills are, hopefully my pipe work will arive tomorrow then i can fit that and all will be done, so aslong as you brave enough and dont mind a grinder then you can fit a big cooler, supose it deppends what you want im not bothered about the fogs as they just blind people and arnt very functional where as a big front mount will actually serve a perpose
  10. #49
    Apr 2008
    122
    Kev, when your done, could you post exactly what you needed to fit your fmic?
  11. #50
    May 2003
    Reading
    705
    Kev, which core did you go for in the end? Is it the one you posted above at 100mm thick? Can you post some pics?
    03 Ebony black S3, Dieselgeek short shift, its started..
  12. #51
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    this is the cooler http://www.thsperformance.co.uk/acat...76mm_Core.html i brought in the end, i was planning to take camara to work tomoz so will up load pics just noticed my pipes were delivered today but no one was home so i might not get them redelivered till wednesday so might not get finished till wed or tuesday, but will take photo stage by stage if posible and list of everyting you will need
  13. #52
    May 2003
    Reading
    705
    Thanks for that, what's the quality of the cooler like? I can't wait to see pics. How did fitting go with the depth of the core?
  14. #53
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    the quality looks good but guess time will tell but does looks good, fitting went ok i havent re-fitted the crash bar yet but its all cut ready so hopefully tomoz ill have the cooler at the right hight and fuly fitted in place with crash bar back on,
  15. #54
    Feb 2007
    UK
    229
    http://00626e1.netsolhost.com/formos...ntercooler.htm
    I like how they used the standard cooler too. Looks neat.
    Wonder how efficient this setup is in comparison to Forge for example.
    Also here - Star FMIC
  16. #55
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    well finally got my intercooler fitted up all level and in the correct position, now just the pipework to route through tomorow when i get to collect them from the local delivery office as they are in cabable of leaving my parcel where i asked as a safe place, ahhh.
    anyway heres some piccys of where im at so far;
    i used some 90 degree angle metal to make a solid level braket
    then i made up a suport bracket underneath to stop the cooler flapping around
    i then trimmed back the crash bar so the cooler would fit behind it
    the final look with the crash bar fitted
    i then had to trim the bumper insert where the fog grills would have gone to allow room for the pipework, im hoping to have this finnished tommorow or thursday as i still have loads of other little projects to do this week
  17. #56
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    oh yeah the top pic isnt me its my gimpy work mate who's helped me loads actually
  18. #57
    Apr 2008
    122
    well, it looks like the crash bar has lost its function.. ?
  19. #58
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Quote Originally Posted by keem View Post
    yep its lost alot of the strength but its not a crash bar for major acidents just minor dings to help stop further damage to the coolers such as air con condensor and radiator its not weakened the strength of the overall chassis or major crumple zone so im not concerened,
    plus if you notic i actually cut away alot more then necassary so if you was to trim away the bare essentials then there would be hardly any diference in strength
  20. #59
    Apr 2008
    122
    yep, i see.. just waiting for the pics with all the pipes and bumper mounted now
  21. #60
    mattm's Avatar
    goldmember.
    Oct 2007
    Cheshire
    166
    kev sweet pics, cheers for the effort to show us
  22. #61
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    so got my pipes to day except the 90 degree elbow reducer from 3 inch to 2.5 inch but as you can see in the pics below its very nearly there now, oh and need some nice clamps to hold the pipe and hoses together, the pipes i got were the perfect size to so no need to mess around chopping to size if anyone is wanting to make the same cooler
    the large gap between the pipe and the joiner above is where the 90 degree elbow has to go
    and then its the same on the other side
    then it looks like this with the bumper back on
    so here is a list of what you need;
    -ths type 4 intercooler
    -viper performance hoses and pipes
    ~ 2* 90 degree 3 inch polished pipe
    ~ 2* 90 degree 3 inch hose
    ~ 2* 90 degree 3 inch to 2.5 inch reducer hose
    ~ 2* 2.5 inch hose joiner
    ~ 2* 3 inch hose joiner
    ~ 2* 3 inch hose 120mm long, i used one 250mm hose chopped in half
    ~ 10* 3 inch hose clamps
    ~ 2* 2.5 inch hose clamps
    http://www.viper-performance.co.uk/index.php
    http://www.powerengineering.co.uk/mikalor/
  23. #62
    May 2003
    Reading
    705
    Looking good. So how much has it all cost then?
  24. #63
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    havent added all together yet but just a shade over 300
  25. #64
    Apr 2008
    122
    Thanks for all the info Kev, you just saved me 300+ (i was thinking about going for the forge kit earlier)
  26. #65
    S£'s Avatar
    Mar 2008
    Suffolk
    669
    Originally i didn't want to cut the crash bar but after what you said about it, i'm now not to bothered i think, as for the fogs I'm still not sure, if a cooler is fitted with smaller pipes, i think someone mentioned 50mm, will the fogs fit in then?? As for the work you've done it;s great to actually see a good guide for people to go by other than the Forge kit!
    THANKS!!!
  27. #66
    s3ollie's Avatar
    Jan 2007
    749
    the fogs fit with the forge kit
    8P S3
  28. #67
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    you could always run the pipe work up side down as danclarke has on page 1, not sure if smaller pipe work would work onthat size cooler as its the length of pipe you need to join to the bend then theres th length of th bend in the pipe think to mount the cooler the normal way up the only awnser would be to use a smaller cooler but then your not going to get the full benefit as surface area isnt going to be increased as muchthus less cooling
  29. #68
    jim s3's Avatar
    Oct 2006
    longbridge, birmingham
    313
    copy cat
  30. #69
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    sorry mate wanted a fmic for a while but wasnt sure how to go about it then i saw yours, yours looks like you have more polished pipework though,
    i hate people who copy one off ideas to so i hate myself, but it looks soo good just had too
  31. #70
    Apr 2008
    122
    Do you have pics with the last hoses fitted?
  32. #71
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    havent recived them yet
  33. #72
    jim s3's Avatar
    Oct 2006
    313
    you will be painting your badges next lol
  34. #73
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    na i like it chrome lol, suits the wheels and mirrors lol
  35. #74
    Apr 2008
    122
    Have you recieved your last hoses?
  36. #75
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    yeah they arrived today actually just waiting for some jubilee clips that i should have for tomorrow then i shall have the job all finnished
  37. #76
    beeitch's Avatar
    Mar 2006
    Madrid, SPAiN
    64
    Just a few pics, i hope it could help you.
    2002 A3 1.9 TDi QUATTRO S-LINE AVUS SILVER with full OEM Bodykit
  38. #77
    Jun 2004
    Crowthorne, England
    2,512
    Looks like you have an oil cooler or two there chap, got any more information or is it just because it's actually warm occasionally in Spain?
  39. #78
    FazS3's Avatar
    Apr 2008
    857
    just out of curiosity,what are the gains to be had from fitting a larger intercooler?i have bin looking at the forge ones but they are very very pricey
    MTM THE ULTIMATE STAGE!
  40. #79
    beeitch's Avatar
    Mar 2006
    Madrid, SPAiN
    64
    Hi, yes on passenger side there is a 13 row oil cooler and also we have installed a fuel cooler (diesel).
    Obviously Spain is warmer than the UK, so we needed to change SMIC to FMIC in order to improve performance with the new hybrid turbocharger. In the other side, diesel cooler prevents injection lack when diesel temperature begin to rise up.
    Sorry for my bad English
  41. #80
    Apr 2008
    122
    whats the status, kev?
