Hi All,
I always wondered about 1.8T engine codes and thought I'd settle this in my head once and for all..
One thing I can't find is a definitive and correct list of technical differences between these engines.The closest things I found was this: http://www.qpeng.com/faqs/engine_faqs/all_these_engine_codes_can_you_explain_what_they_mean.html
My S3 is 03 plate with an AMK engine and just wondered how different it is to the BAM engine, with 225hp. They both have the bigger K04 turbo, Variable Valve Timing, Drive By Wire and on paper seem to be identical apart from their power output rating.
It seems like the main difference is the ECU map from factory and remapping them seems to result in similar output.
Anyone know if there are any mechanical differences I missed? Different valves or something?
Thanks.
Thanks.
