    vbking's Avatar
    Dec 2004
    Bristol
    20
    Climate Control Problem
    Hi chaps,
    A few days ago my air conditioning stopped 'conditioning' air. Regardless of the temperature setting, air is not being cooled.
    I have done a bit of self-diagnosis based on other threads and can confirm that the magnetic clutch on the compressor is NOT engaging, and VAG-COM is reporting NO error codes (and to confirm, ECON is not on).
    Does anyone have an idea about what might be wrong or where else I should be looking? Failing that, i'll have to book it in and get it looked at.
    Any help would be much appreciated!
    Chris
    Jun 2003
    west yorkshire
    90
    Hi I would expect it needs regasing
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    as above, might be regassing needed.
    ^^ In my opinion
    kevsn's Avatar
    3rd gear
    Jul 2008
    teesside
    77
    hi
    i had the same problem. had it regassed but made no difference in the end it was the wiring to the compressor which needed rewiring(no positive). had mine done under warranty so not sure how much this would cost. like others said might just need regassing
    2001 51 silver s3. unknown remap, 280 bhp, forge 007p dv.
    vbking's Avatar
    Dec 2004
    Bristol
    20
    Thanks guys, i'll see if it needs re-gassing and go from there.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    If it needs regassing you could well have a leak usually occurs at the condenser.
    99 S3 Absolute red
