Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Mickeybhoy67
Thread: Throttle position sensor
    Feb 2006
    glasgow
    45
    Don't mean to be stupid but can anyone tell me where it is located on an Audi A3 98?
    Cheers an advance!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    It is incorporated into the the throttle body under the black plastic cover.
    Feb 2006
    glasgow
    45
    Is it easy to replace????
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Just to double check, you have a cable operated throttle, correct and you are getting some sort of error code relating to the throttle position sensor?
    Feb 2006
    glasgow
    45
    Yes that is correct
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Just checking it wasn't DBW.
    You could try disconnecting the battery for about 20mins and then re-aligning the throttle body. Do this by turning on the ignition without starting the engine or touching the throttle body. Wait for the high pitched noise from the throttle body to stop and then see how you go.
    If it's still not right then it's a new throttle body unfortunately as the sensor cannot be removed separately as far as I know.
    Is the car not idling or something?
    Feb 2006
    glasgow
    45
    I took to a couple of garages, one of which was an Audi specialist in Duntocher who done a diagnostic which gave out the following faults:
    00518 - Throttle Position Sensor (G69)
    31-00 - Open or Short to Ground
    01087 - Basic Setting Not Performed
    27-00 - Implausible Signal
    00530 - Throttle Position Sensor (G88)
    31-10 - Open or Short to Ground - Intermittent
    Basically the car starts ok when I turn the key however it dies straight away. I have to keep my foot on accelerator for a few minutes to keep the revs up then car is ok however idle set usually at 1ish
    Mido likes this.
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Yup, sounds buggered. It will probably be a new throttle body then. The specialist should first check the wiring though, just in case its a wire break rather than a component failure. However, I suspect it's the latter.
    Have a look on Ebay as the dealer will want about 430 for a new one.
    Feb 2006
    glasgow
    45
    Its not the throttle body as I took into my local garage and they tried another throttle body, and took another diagnosis which gave the exact same readings!!!!!
    Nov 2013
    I have the same problem and I replaced the throttle body and it still the same
    if you fixed it please tell me how
    Nov 2013
    Quote Originally Posted by Mickeybhoy67 View Post
    same problem need someone to tell us how to fix it
    RGL
    RGL's Avatar
    Free breather
    May 2013
    Way up north
    40
    As someone already mentioned, it is possible that the throttle body itself stopped working properly. However it would be wiser (and much cheaper) to first try to check all the wires running to and from it for splits or any other damages, since these "Open or short to ground" and signal codes have often to do with the wiring. Cleaning the throttle body can't hurt either but I'm pretty sure it won't fix those faults. Either it's the wiring or the throttle body itself has lived it's life. Just try all non-cost/cheap measures like checking the wiring, cleaning and re-aligning first.
    Nov 2013
    I replaced the throttle body and these errors remained
    I checked the wires and it seems ok .. and all fuses ok and cleaned the throttle body
    I don't know what else to do
    Nov 2013
    does Audi A3 1998 1.6 petrol throttle pedal has a sensor ??
    if it does where its location plz
