Monster MotorsportEM Tuning
    texas_venom316's Avatar
    Apr 2008
    17
    Do u need to recode a g202 accleration sensor??
    My old one was faulty so i had another pert worn one fitted from a tt on my 2000 s3 but it still has a similar problem.
    Before the turbo would only work in 1st gear but now since ive put the new sensor in , the turbo chooses when it spools up, sometimes for example it will work in gear 1 and sometimes it wont ??
    Do these sensors actually need to be recoded ??
    thanks in advance
    jesters3's Avatar
    The Shire's
    1,516
    Pass, but found these http://www.kisolutionz.com/ttforum/mk20abs_sensors.PDF and http://www.wikitt.org/wikiTT/images/...kers-Guide.pdf
    However I can't locate the 'basic settings', maybe worth giving a stealer a call or your local specialist?
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Apr 2008
    17
    that was a great help, cheers mate, ill try posting on here and see if anyone knows
    jesters3's Avatar
    The Shire's
    1,516
    Had a look on Ross Wiki
    http://wiki.ross-tech.com/index.php/...#Basic_Setting
    Not for a g202 though...
    But this is: http://wiki.ross-tech.com/index.php/...ke_Electronics
    But is based on a Passat...
    Jester
    jesters3's Avatar
    The Shire's
    1,516
    Oh and feck knows if it will fix your problem as I have not got a scooby so you are on your own there fella!
    Jester
