Thread: Viper DV
    Mar 2004
    238
    Viper DV
    The screw on top of the DV where the vacum pipe connects seems loose, when you move the pipe the screw turns is this correct?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,581
    Re: Viper DV
    Mine does that some times........want to get some nylock
    Mar 2004
    238
    Re: Viper DV
    just wasn't sure if it was meant to be loose but as yours is the same I guess so
    PaulRS3's Avatar
    UK
    1,006
    Re: Viper DV
    its meant to be tight. i tightened mine down with a spanner.
    Mar 2004
    238
    Re: Viper DV
    could this be the cause of another problem I have. When the revs climb slowly in first and second ie my foot is only feathering the throttle I get little blips where it feels like I've lifted off altogether
