[ QUOTE ]
dunk said:
does the shark aerial do the radio? i thought it was gps and telephone - it certainly is on the latest s4.
i changed my radio whip on the roof to the audi triplex (gps/radio/phone) - you have to remove the boot side trim on the left, the pillar trim then the central rear roof trim behind the rear roof lights - the aerial has a toothed nut that simply unscrews - remove the old aerial, pass the new leads through the roof hole and put back the bolt.
you may find that the leads/connections are very different - the audi triplex aerial uses the radio lead connector for the gps signal and different connectors for the radio and phone - i cut the new aerial connectors off and soldered the leads but had to dismantle the triplex aerial to start with to work out which of the 3 leads was which function - they areent labelled at all.
[/ QUOTE ]
Dunk, have you got pics to show the fellas what you are talking about? In terms of it's looks that is.
