Chris NottSky Insurance
    807
    how to refit drivers side cubby trim
    hi i removed the trim under the sterring wheel with the light switch etc on, to look at the G200 sensor as i will need to replace it at some point.
    However im having a nightmare trying to get the trim back in place correctly so all the screws line up. Elsa says "When installing, slide bottom of compartment into the two guides." what are the 2 guides? is it the white plastic clip things becuase thats what i tried.
    any tips would be great thanks
    Ben
    807
    bump anyone got any tips please gonna tackle it in a bit again
    Ibzzzzz's Avatar
    Apr 2007
    666
    that'll be these two guides
    When i was having the same problem i found that taking out the whole headlight switch helped, IIRC you push the switch in and turn it by the time it gets the sidelights position it should come out.
    2006 - A4 - 1997 1.8T 20VS, Full Black Recaro Leathers, Concert, Climate Control, Facelifted, Remus, Front armrest! - Sold
    2007 - A3 20vs -bridge gap motor....
    2008 - Think its time for the Civic Type R.
    2009 - Screw a Type R. Got a VR6 instead (missed even now)
    2011 - Focus St170. < what was i thinking...
    2012 - Lateee 8L S3 with EVERY extra....Broken...other asn members enjoying my parts!
    NOW! - B5 S4 Avant - 2.7 Twin Turbo POWWEERR! WWOOOOOSSSHHH!
    Ibzzzzz's Avatar
    Apr 2007
    666
    Plus have you got it into this clip too?
    807
    Wicked thanks for your help, all done now, will have to do it again to replace the sensor but feel like i can do it now. tx
    Ben
    Ibzzzzz's Avatar
    Apr 2007
    666
    No Problem!
