Monster MotorsportVolks Autos
Results 1 to 11 of 11
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Why does the car cut out when...
    .......aircon is switched on on idle.
    The revs start to drop and then car turns off.
    I have run vagcom and there is no fault codes.
    Any help please.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    There is an idle speed compensator for the load placed by the AC compressor. Its clearly not working.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    where is that exactly?
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Quote Originally Posted by abdus View Post
    in the car
    sorry i have no idea
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Quote Originally Posted by rickparmar View Post
    in the car
    FAIL....
    should be in the engine compartment
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    When the aircon is switched on the ECU logs the change. Idle should be increased via the throttle body. If that isn't occuring, either the throttle body requires cleaning an re-aligning or you have a vacuum leak.
    Is your idle at all lumpy when the AC is off? Idle can be adjusted to raise it a little. Not sure if there is a separate idle setting for when AC is on, probably not.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,846
    Quote Originally Posted by HTC View Post
    Whilst on this subject, don't suppose you know if a 1.9 PD diesel motor has the same sort of thing? I'm having issues similar with my Passat.
    Thanks.
    You've got to have a laugh!
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    idle is perfect when aircon is off.
    it only happens when aircon is on and some random times, it doesn't do it at all.
    I followed steps regarding throttle body re-alignment on vag-com, it said all was fine ADP OK etc...
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    Quote Originally Posted by jojo View Post
    Thanks.
    Yes, if i remember correctly, there is a throttle bypass valve which opens and controls the idle speed, it get ****ted up and needs cleaning out.
    I may be thinking of another engine, maybe someone with EKTA installed can look at the intake diagram and confirm?
    Chris
    See my images @
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    all sorted...
    throttle body needed a clean
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    oven cleaner is the best stuff to clean them with...
    Chris
    See my images @
