Chris NottSky Insurance
Results 1 to 17 of 17
    S3 Chris's Avatar
    Jul 2008
    Aberdeen
    58
    Question S3 Engine Whats Where in Pictures?
    Not being very technical I dont know my DV from my MAF. Basically I dunno whats what under my bonnet (Well OK I know which is my DV......just! ).
    Are there any pictures/diagrams kicking about that show what is located where. Pretty basic I know, sorry guys
    Had a search through the forums but with not too much luck, Ive only found a picture of where the N75 valve is. So I was wondering if there are any pics or diagrams out there that identify the commonly changed parts that are talked about in this forum quite often such as the MAF, TIP, N249 Valve, O2 Sensor, Oil Breather, EVAP Canister, Vaccuum hoses, etc etc etc.
    I could always take a pic of my engine bay and some kind soul could draw a few arrows and names on it?!
    Also Ive just installed elsawin but not attempted to use it yet - but perhaps this contains some diagrams etc that may enlighten me?
    Cheers in advance
    S3 is gone
    jesters3's Avatar
    The Shire's
    1,516
    Check out Wak-tt.com website, there is loads of good information to use: http://www.wak-tt.com/mods/engine.htm
    Also for a picture of a 1.8T Engine:
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    this also might help (not sure how close it is to the S3 engine though)
    look down the page for the diagrams and labelling
    http://forums.vwvortex.com/zerothread?id=2666114
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    *another noob question* is the N249 valve simply the diverter valve?
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    or is it the N75? lol
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    The divertor valve can be found just under the back right corner of the engine cover on the S3 (big thing, small tube going into the top and two bigger tubes). It's not the N249 or N75, those are both little valves on various parts of the vacuum / boost system.
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    This thread saved me making my own topic..
    here's a question for you..
    what is the plug connector seen in the below image!? (right hand side at the front (as you look into the bay) near the headlight housing)
    Upon investigation earlier, I noticed it wasn't connected to anything..?!
    Also, I have a split/hole in a hose (breather pipe?)
    This needs replacing, obviously. But will it be doing any damage for now? The car does smell rich at the minute, could this be as of result of the split?!
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    anyone?
    27,073
    its the headlight levelling motor connector which is actually right next to your hand, it pushes into that plastic squarish thing with rounded side so feel underneath & you will feel a socket etc for it to plug into & yes the split would make a difference overall given pipe location is obviously linked to airbox/turbo/valves location & most times one of these pipes splits it affects cars overall usability mate, tape it with duck tape, it also looks very flat aswell, you sure it hasnt or isnt been squeezed flat while under hood?
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Quote Originally Posted by nigelhobden View Post
    ah! sorry, I didn't make myself very clear. I knew it was to plug into the seen socket, just I wasn't sure what I had been 'missing out' on! (as it wasn't plugged in!)
    The pipe.. now.. this is an interesting one. The car was into Quattronics early June for a quick looking over.. one or two issues arose, and a couple of pipes were replaced. I'm sure this was one of them (not a new pipe by any means, just, a 'spare' for the mean time.) It is very squeezy and needs replacing. But for now if I duct tape the hole I will get by?
    Thank you.
    Jun 2004
    Crowthorne, England
    2,512
    The wire has probably been disconnected because they don't self level properly so you might not want to re-connect that if you can see okay at the moment.
    I can't quite picture which pipe that is without going and having a look, any other photos?
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Can someone please confirm that the connector is infact the headlight levelling socket?
    The reason I ask, as on the way to workt his morning (before being sent home, ill) I gave the screen a blitz with the squirters.. Now, it was hesisitant to fire, and when it did, it misted very much so, only after a few seconds and retries did it 'squirt' as it usuall would. Thought nothing more of it..
    However, when I got to work, I noticed the bonnet/lights were soaked. Hey! I have headlight washers!! (now I know all S3's have the cutout section in the bumper, but I never knew I actually had them. They were there as dummies, if the car hadn't actually got them or not) And I can't so much say that until I recconected that plug, I ever noticed them.
    Chances are it's just fluke, and it is the headlight adjustments, either way though.. thanks for the input!
    The pipe is just underneath the big Audi engine cover. To the right hand side of the head, next to the intake pipe/airbox?!
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Oh, very much so. Thank you.
    jesters3's Avatar
    The Shire's
    1,516
    The pipe is coming off the TIP and is to do with your ESP, i have the same dodgy pipe, for price and parts check out here http://audi-sport.net/vb/showthread.php?t=58197
    I have had the pipe as it is for quite a while ( I know I know should have changed it earlier) with no DTCs, Oil loss, Boost loss or anything and the brakes still work fine as does the ESP - even so get it sorted.
    Jester
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Jester I can't work out which of the part-numbers on the diagram the offending pipe work is?!
    I have noticed a bit of an oil loss if I'm honest, so I must now be careful.
    jesters3's Avatar
    The Shire's
    1,516
    2006A103817
    connecting hose / for vehicles with electronic stabilisation program -esp-
    Jester
