Chris NottEM Tuning
Thread: Coolant level ?
    Dark Knight
    Jul 2008
    936
    Arrow Coolant level ?
    Hi all ,
    just a quick question i have x 2 1.5litre of audi coolant is that enough to fill the system up ?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Yes, that will be more than enough. The cooling capacity is about 5 litres. You have 3 litres of G12+ which would give you a 60% mix (this is assuming the system is completely dry before filling. If there is residual coolant in the block or heat exchanger, then the mix will be more that 60% G12+"
    Mixture should be at least 40%, but no higher than 60% as boiling protection is reduced.
    I would mix your G12+ with water to 40% in a separate container and then add it to the engine. You know you will have the correct mix then.
    G12+ (40 %) and water (60 %) for frost protection to 25 C.
    G12+ (50 %) and water (50 %) for frost protection to 35 C.
    G12+ (60 %) and water (40 %) for frost protection to 40 C.
    Dark Knight
    Jul 2008
    936
    Arrow Thanks
    Hi ,
    Thanks for that info ,
    whats the best thing to do try and drain in or just mix it . So just mix it in a jug should i use both the bottles ?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    No need to drain. Just mix up the desired percentage of coolant to water into a separate container. Then pour in. You know the mix is correct then. If you have any left over, just store it for top up if required at a later date.
    It will take less than 5 litres. I would mix up one bottle with water then see how you go.
