Badger5Sky Insurance
Results 1 to 16 of 16
Thread: my S3
    Re: Ordered It!
    Steve - about the climate comfort screen / gps thing.
    Does it completely block the signal to the device ?
    Is there any solution ?
    Ive got a bel 996r here at the moment, and Im in two minds to get it fitted, or send it back and get a gps and radar/laser detector combo instead.
    tks
    will
    Jul 2003
    200
    my S3
    nothin to do tonight so I thought I would put some spec on to the board. Nothin special (Ess_three don't laugh ok? ahha)
    AmD Chip
    AmD DV
    R32 rear anti roll 19mm
    H&R Coilover Sport
    Milltek cat back (damn those cats are expensive)
    Stoptech brake setup
    SPEC stage 2 clutch and lightened fly wheel
    Apexi boost gauge with controller
    Samco hose(s)
    Soon to be on list:
    Star performance front mount
    looking aroudn for a turbo upgrade ... IHI ?
    new wheels, ex owner crapped up all 4s
    Any other suggestions are welcome!! (even better if you can sponsor me for it hahahaha)
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: my S3
    [ QUOTE ]
    [/ QUOTE ]
    Me? Never! You have a very wrong opinion of me... [img]/ubbthreads/images/graemlins/angel.gif[/img]
    I'll give you my personal opinions on the list:
    [ QUOTE ]
    AmD Chip
    [/ QUOTE ]
    Good choice...just don't get too highly strung over the accuracy of the dyno plots.
    [ QUOTE ]
    AmD DV
    [/ QUOTE ]
    Not really any better than the Forge unit...still needs overhauling every couple on months.
    [ QUOTE ]
    [/ QUOTE ]
    And no front upgrade?
    Brave man...
    Here comes my rear end...my front will be along in a minute!
    [ QUOTE ]
    H&R Coilover Sport
    [/ QUOTE ]
    After this weekend's research, I'd look into KW too...excellent product!
    [ QUOTE ]
    [/ QUOTE ]
    Nice sound...barely adequate fit, not worth the money in terms of gains...
    [ QUOTE ]
    [/ QUOTE ]
    Good choice...
    Better than the Porsche set up? Who knows...
    For trackdays...great.
    For road use, the Brembo kit is superb and will save you enough to buy the Milltek cats!!
    [ QUOTE ]
    [/ QUOTE ]
    Probably a wise upgrade... [img]/ubbthreads/images/graemlins/smirk.gif[/img]
    [ QUOTE ]
    [/ QUOTE ]
    With an AmD re-map?
    Odd.
    Just not required...
    [ QUOTE ]
    Samco hose(s)
    [/ QUOTE ]
    Looks very pretty...
    Standard do the same job...
    [ QUOTE ]
    Soon to be on list:
    [/ QUOTE ]
    Excellent upgrade...
    [ QUOTE ]
    [/ QUOTE ]
    IHI from Jabbasport...had a long chat to Mike on Sunday...damn good product and well sorted. Proven time and time agian...that's the one to go for.
    [ QUOTE ]
    [/ QUOTE ]
    Resist the temptation to go too big if you want handling...
    If 'bling' is your thing...then fit the biggest, shiniest, heaviest cheap ass wheels you can find...
    If not try to stick to 8" wide and go to 18"...they offer the best compromise.
    Also, get the best / lightest wheel you can afford...makes a big difference to the handling.
    A 8" x 18" BBS 2pc wheel with tyre will weigh in at about 1 lb LESS than the standard 17" set up...offering more grip and less work for the suspension to do.
    Good luck...and enjoy!
    Rai
    Apr 2003
    17
    Re: my S3
    [ QUOTE ]
    [/ QUOTE ]
    Interesting, the TT guys in the US have been putting 19mm Neuspeed Rear ARB's on for years in combination with the stock bar up front. They swear by it, love the results and have not had any snap oversteer probs. Neuspeed is too expensive here for me to justify the upgrade.... is the R32 19mm ARB a direct bolt-on to the S3?
    Jul 2003
    200
    Re: my S3
    yeh AmD do a lot of direct bolt on of hte R32 anti. Bascially the reason i missed out on the front anti is because it cost so much to install. Also i have not research into how many "mm" i should go for (ess_three recommendations?)
    No blings for me please. Sportec 18 are the max size, but I heard OZ are really really light.
    Boost gauge installed for future engine mods~
    Agree on the milltek barely adequate fit!!
    I have a collapsed intake pipe hence the addition of the samco (perhaps of all the hype about it as well)
    Star performance upgrade definately awesome and awesome price, must get.
    How many of us on the forum are using the IHI upgrade from Jabba? Would love to hear some comments and reviews!! or anyone tested one
    Jul 2003
    200
    Re: my S3
    one things about the coilovers, as stock, my front end is pretty low compare to my rear, and my friend told me to lower the front by 10 and rear by 15. any comments
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: my S3
    [ QUOTE ]
    [/ QUOTE ]
    I can believe they have..
    But TTs handle differently to S3s...
    And having been down the road previously of having a car with a really big rear ARB that 'didn't suffer any snap oversteer' until one wet day on a muddy road...result: one written off car.
    The potential is there...one day it'll bite you.
    All I can say with utter confidence is that the set up I run has NO understeer, NO oversteer and WILL NOT not bite you under snap oversteer conditions. Believe me, myself and David R have tried!!
    My S3 is totally neutral now...
    You can take many liberties with it...
    You can do things with it that shouldn't be possible...
    And this is with both front and rear ABR upgrades.
    I personally, couldn't drive a car 10/10ths if I suspected it had the ability ro bite you...it's not relaxing.
    Maybe the rear bar will kill the understeer, but I find it hard to believe that you can dial in enough front end confidence using a standard front ARB, to be able to really push the limit...the standard bar just doesn't allow you to do this, in my opinion.
    Woodster's Avatar
    Welcome to my world...
    Dec 2003
    Mighty Mighty Yorkshire
    83
    Re: my S3
    [ QUOTE ]
    Ess_Three said:
    [ QUOTE ]
    AmD DV
    [/ QUOTE ]
    [/ QUOTE ]
    Hi
    Just wondering what is required for overhauling the DV? Had mine on for a couple of months now, so it could be due... [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    Rich
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: my S3
    [ QUOTE ]
    Woody_S3 said:
    Hi
    Rich
    [/ QUOTE ]
    I notice it needs attention when you don't feel the car is as smooth...it hesitates coming on-off throttle and somtimes seems to surge on full throttle out of certain corners.
    Each time I've cured the problem by overhauling (cleaning & re-lubricating) the DV.
    Woodster's Avatar
    Dec 2003
    83
    Re: my S3
    I thought as much, I've felt engine hesitate a bit before the power comes in a couple of times.
    I'm going over to Wales at the weekend, so it'll give me a good chance to see how it runs.
    Maybe time to get the spanners out...
    Rich
    Jul 2003
    200
    Re: my S3
    Ess_three
    2 things I want to ask you:
    What size front anti roll do you have. and what do you recommend to get now for the front (19mm at back)
    2) Is it a good idea lowering 10mm at front and 15 mm at rear
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: my S3
    [ QUOTE ]
    cyuen said:
    Ess_three
    [/ QUOTE ]
    I have 22mm front, 19mm rear.
    I would suggest that the 22mm Neuspeed bar works really well...but there may be a VAG 21mm or 23mm that would also work as well.
    I can't remember what the R32 runs? Or some of the A3 quattros...anybody remember off the top of their heads?
    [ QUOTE ]
    [/ QUOTE ]
    I can't forsee a problem with lowering those modest amounts.
    Should be fine.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: my S3
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    north or south wales??
    Woodster's Avatar
    Dec 2003
    83
    Re: my S3
    [ QUOTE ]
    [/ QUOTE ]
    North Wales Pete, Bala. Going rafting, so I might not be posting for a while as I recover from the broken bones...
    Rich
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: my S3
    [ QUOTE ]
    Woody_S3 said:
    [ QUOTE ]
    [/ QUOTE ]
    Rich
    [/ QUOTE ]
    i'am going to bangor for a week then down to carmarthen for week if you or anyone see's a ming blue S3 flying around wales at the speed limit [img]/ubbthreads/images/graemlins/angel.gif[/img] give me a flash
    ps good luck with the rafting
    Woodster's Avatar
    Dec 2003
    83
    Re: my S3
    [ QUOTE ]
    [/ QUOTE ]
    Will do, have fun
