Sky InsuranceEM Tuning
    Apr 2004
    Sydney, Australia
    262
    Need a bit more power.
    I wanna stick on an induction kit just to get a bit of noise going and a tad more power. I dont want to bulls up the MAF so oil coated ones are out the question. Any recommended induction kits for me then? Also can I fit i myself and what will my insurance increase by approx when i declare it. Cheers.
    Oct 2003
    396
    Re: Need a bit more power.
    It will make sod all difference to the power but may make a nicer noise. Depending on the type of filter it may stay cleaner longer than a paper filter and therefore reduce power loss (not the same as a power gain).
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    Lee,
    This has been discussed many times...so please use the search function.
    Anyway, I would say just drop in a replacement panel type filter if you really have to upgrade. I wanted a bit of induction noise and a bit of bling under the hood which is why I fitted a carbon fibre airbox with a stainless steel filter....but you'll see there are different comments on the forum about the pro's and con's of each of the filters.
    Apr 2004
    Sydney, Australia
    262
    will do!!!
