Chris NottEM Tuning
    Jul 2008
    S3 temp gauge / sensor problem.
    Please can somebody help me out with the following problem on my 2002 S3?....sorry if this has been asked before but I can't find an answer.
    The temperature gauge is OK for most of the time...sits nicely in the middle at 90. However, sometimes it doesn't move from 60 at all then while I'm driving along it will spring up to 90 and sit there as it should.
    Also....sometimes it goes to 90 and stays there as it should....then it can drop to 60 for a while ...then go back up to 90 again with no warning!!
    It seems electrical to me due to these symptoms...could it be as simple as a loose connection somewhere?
    Thanks,
    B.
    Jun 2003
    World of my own
    9,813
    Temp sender is shot. Easy 20 replacement from dealer, DIY fit.
    Alex Turner
    Jul 2008
    Thanks for the reply....I have an AMK engine....would anybody know where I find the temp sensor on this engine and what part I need from Audi?
    Cheers,
    B.
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    audi should give you the correct part
    theres a guide for fitting it yourself here, it's for the 225 bhp BAM engines but there shouldn't be too many differences
    http://www.wak-tt.com/tempsensor/tempsensor.htm
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
