JMB RetrofitsVolks Autos
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    Brake switch problems
    Hiya chaps!!
    Just thought i'd wack a post up on this..... noticed my brakes weren't working at the weekend and headed straight to the pedals to replace the switch.....
    I had loads of problems with this on my 99 1.8T where i bought pattern parts to replace and had to keep stripping the switch as it worked on a sliding contact.... the switch on this car however looks upgraded, unsure if its the same plugin, the switch is a barrel design......i took this apart and noticed that a round piece at the top of the barrel had turned slightly making it not work correctly....
    Tip is to check this before replacing as the new design is not a sliding contact so shouldnt wear as fast as the older switches. Probably save you 20 if anything but a tips a tip
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    947
    What was the problem exactly mate,i have probs in that area too!
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    the connection stops the lights working.... or makes your brake lights flicker on the old switch
    Jul 2007
    95
    I wrote a guide for doing this on my Leon. It may come in handy for someone
    http://www.seatcupra.net/forums/show...ht=brake+light
