Hi All,
My break light went out on Friday, so yesterday I changed the bulb, to find that it still doesn't work. With this I then checked the fuse for the break lights, to find that it was fine.
Hmmm. With this I then check the actual bulb with a volt tester and it was fine, I then tested the contacts on the fixture to find that no voltage was present.
I know what usuallt the wiring loom comes up one said of the car then splits onto the opposite side.
Has anybody else had this problem? If so how did you overcome it? Also would a diagnostic pick up were the issue is?
