Badger5Chris Nott
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    Vibration through steering wheel/car
    I have a 2001 A3 1.8t with 36,500 miles which I bought a few weeks ago. I have noticed that there is a vibration through the steering wheel when I lift off the accelerator when above 80 mph.
    At first I thought it was wheel balancing, but would that not cause vibrations when accelerating as well as decelerating?
    I am now starting to think that it is something to do with the engine as when I lift off at 80 I get the vibration through the wheel and can feel it through the car as well and it also kind of sounds like the engine is gurgling - weird I know, but it is the only way I can describe it!
    Does anyone have any ideas what might be causing it?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,537
    Re: Vibration through steering wheel/car
    Check your engine mounts as one coould have failed.
    I think Gambba had this problem too once
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    Thanks Mike, I will get the engine mounts checked out.
    Its definately not the wheel balancing as I had that done this morning and it has made no difference.
    I don't think it will be the engine mounts/engine related as the vibration is still there if I put the clutch in - maybe gearbox mounts??
