JMB RetrofitsChris Nott
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Clutch master cylinder or flywheel
    Got a problem with my clutch, after a few minutes of driving the pedal sinks to the floor and won't come back up, clutch bite ends up near the floor (although the clutch is fine, no slipping etc).
    I've been told this is either the master cylinder of flywheel? I've got a receipt showing that the slave cylinder was done in the last 15k so im assuming thats still ok.
    Is there any way to tell which is going other than replacing the master cylinder and hoping for the best?
    Dont fancy spending big at the minute
    h100vw's Avatar
    Aug 2006
    Down South, next stop Antarctica
    215
    Is the fluid level in the reservoir normal. Could be fluid leaking past seals in the master cylinder. I would be doing the master cylinder before having the gearbox off.
    Gavin
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    Either master or slave, As you slave has been changed it looks like being master. 50 will get you a master cylinder and a good few hours to fit it!!!
    Its not unheard of slaves failing even after being replaced though!
    Black S3
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Cars going in tomorrow and i'll find out whats wrong then.
    Currently in work waiting for a lift home as I have no clutch pedal
