Chris NottEM Tuning
    Nov 2007
    49
    Replacing the thermostat
    Had an attempt at replacing my thermostat earlier following this: http://forums.audiworld.com/tt/msgs/1304892.phtml
    I think thats for a BAM engine on a TT, I've got an APY and the whole area around the lower bolt seems a lot tighter - I can barely get my hand to it let alone anything else!
    I can get to the top bolt fairly easily with a ratchet and universal joint, but the 10mm socket just keeps spinning off/over the bolt whenever I put some force into it!
    I'm clearly doing something very wrong, so suggestions please before I try and get it booked in at the local specialists.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    It's a ******* of a job to get to it, although some people claim it's not that bad....
    Personally, I took one look at it, and decided that my socket set was too large to get in there.
    If you had a decent 1/4 drive socket set with several different extensions and UJ's I reckon it can be done easily enough.
    Good luck!
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    the job is a pain in the ass, i found that a small rachet from maplins of all places (about 4) was the saving grace....
    this has to be the most useful tool i have ever bought.
    Call of Duty Zombie Slasher.
