Results 1 to 14 of 14
    Feb 2008
    529
    clutch help (master and slave cyc)
    right not long after i picked up my S3 the famous clutch pedal snapping happened, got it fixed under warrenty but now my clutch pedal has started squeaking and depending on the weather i can feel movement in the pedal (it'll reach a point when pressed down then clicking noise happens and the pedal will move a few more mm) now all i can think it could be is when my pedal snapped it has damaged the master or slave cyclinder. my other question is is the pedal attached too the master or the slave?
    hope you can understand what im talking about.
    thanks Gav
    Audi A4 Avant 1.9TDI Quattro Sport 2004
    Shy19s's Avatar
    Oil running through my veins.
    Apr 2008
    London
    902
    Is your clutch electric or on a cable? If its on a cable, have a look it might have just come loose.
    Totally addicted to boost.
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    The Pedal box is connected to the master cylinder, that in return pushs the slave cylinder in the gear box, i cant see that the snaping of the pedal box would damage the master or the slave. Just hope its not your slave on its way out as its a gearbox off job.
    When my slave packed up it went with out notice.
    Hope this helps
    Black S3
    Feb 2008
    529
    cheers bud
    i've just notcied after about 20min of driving the biteing point seems to change.
    just when i was reading into the pedal problems id read a few threads saying that peopel had too replace there master as the force from the pedal springing back bent the rod in the cyclinder.
    schwartza3's Avatar
    Sep 2006
    Melburg Australia
    48
    i think your clutch fork is bent,
    it hits the rotating pressure plate which makes the clicking noise.
    pedal moves in a few more mm as the fork is bent even forther untill you won't be able to engage the clutch any more
    edit: the part is cheap but the box has to come out to replace it
    98 A3 / 1.8T AGU / K04-001 / GIAC / 4bar FPR / N75J / FMIC / 2.5" Turbo back / GFB DV / Turbo Intake / FK Highsport coilovers / ECS Stage 1 Clutch
    Feb 2008
    529
    ah bugger.... might have too get a run around till i can afford too fix it. cos while the box is off might as well change the clutch too.
    Jacko4130's Avatar
    Goodie Gum Drops
    Dec 2007
    mansfield
    839
    And maybe the flywheel.
    Black S3
    Feb 2008
    529
    yer, might as well spend more money
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    did you starighten the push rod when you replaced the clutch pedal mine squeaked after i replaced my clutch pedal so i straightened the push rod from the mastercylinder out even more and its fine now,might be worth checking that
    A4 TDI S-LINE
    Feb 2008
    529
    i didnt fix it my self, garage where i got it from sorted it. is it much over a job too get the master out? or did u do it while it was on the car?
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    i starightened mine while it was fitted,if you removed the clutch pedal a set of mole grips will do the job depends on how good you are at diy with cras,im a mechanic so i found it quite easy but if your not very handy with cars maybe leave it to someone else,its not a big job though really just a bit fiddly.
    A4 TDI S-LINE
    Feb 2008
    529
    im ok with some stuff, i mean i aint shy so i'll give it ago, if i do happen to get stuck ive got plenty on mechanic mates that will come too the rescure.
    cheers mate
    danotto's Avatar
    VAG HUNTER
    Jun 2007
    Berkshire
    1,084
    how did you get on gav,sorted it yet?
    A4 TDI S-LINE
    Feb 2008
    529
    alright bud, i aint got round too sorting it yet, as ive had my timing belt done last week and before i can sort the clutch prob i need to repalce 4 tires. once i get the tires done i will get onto the case of my clutch as well as my driver door latch and the final prob my miss reading fuel gauge haha i love my car, always keeps me busy.
    cheers for asking tho
