right not long after i picked up my S3 the famous clutch pedal snapping happened, got it fixed under warrenty but now my clutch pedal has started squeaking and depending on the weather i can feel movement in the pedal (it'll reach a point when pressed down then clicking noise happens and the pedal will move a few more mm) now all i can think it could be is when my pedal snapped it has damaged the master or slave cyclinder. my other question is is the pedal attached too the master or the slave?
hope you can understand what im talking about.
thanks Gav
thanks Gav
