Results 1 to 10 of 10
    Jul 2003
    Berkshire
    150
    Question Have I got the right spark plugs for my S3
    Went into GSF for a few bits the other day. Asked for a set of standand spark plugs for my MY2000 pre-facelift S3 (APY engine code). They gave me Bosch Super Plus FR7KPP33+ - anyone know if these are the right ones before I start the job?
    Jan 2007
    Hertfordshire
    520
    Thank god you are checking, GSF are pants for providing the right part.
    Jul 2003
    Berkshire
    150
    Well for a start they are 0.7mm but everything I read on here says the gap on an S3 should be 0.8mm?
    Could it be different for each spark plug model or engine code?
    buckas's Avatar
    Sep 2006
    south west wales
    750
    take the ones out and look what they are - mine were NGK PFR7Q so replaced them with the same
    guide to get them out - http://forums.vwvortex.com/zerothread?id=2964360
    Jul 2003
    Berkshire
    150
    OK... anyone know from memory what size spark plug socket is required?
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    they tried to sell me the Bosch Super Plus but I insisted on NGK, iooo there not cheap .... then said about 8 quid each instead of 7 quid. sure mine are NGK PFR7Q also.
    red to red black to black blue to bits
    Wak-VAGCHECK's Avatar
    Feb 2007
    47
    1.8T's usually have NGK PFR6Q plugs as standard, 7 on NGK would be 1 heat range colder. Bosch go down in numbers to get colder plugs, but I dont know what the Bosch plug would be to be equivalent to NGK
    We stick to NGK where possible.
    Feb 2004
    2,036
    I think "6" in an NGK is "6" in a bosch, but yes, they go the different way, so "7" (cooler) in an NGK is equicv of "5" in a bosch. Would not use Super 4's in a 18T engine.
    Try PFR6Q for a stock engine, PFR7Q if you have an "agressive" remap (otherwise stock is fine). Or save shed loads and buy NGK copper BPR 6E (or BPR 7E for cooler) at 1.99 each!
    Jul 2003
    Berkshire
    150
    So Bosch FR7s that I have are actually hotter than standard?
    They aren't Super 4s, just super plus - only one electrode.
    Jul 2003
    Berkshire
    150
    I took one plug out last night and it was NGK, and although it would have fitted, it clearly had a bigger gap than the Bosch one. I'm going to take the Bosch ones back to GSF and get NGKs.
    I couldn't find any reference to the Bosch part number online. Their lookup chart says I need 'N30' plugs whatever they are.
    Also I snapped the tab off the coilpack connector - whats the knack to getting these off without breaking them?
