Chris NottSky Insurance
Results 1 to 8 of 8
Thread: Trolley Jack
    Jay
    Aug 2006
    323
    Trolley Jack
    I need to jack the front of the car up wheres the best point to position a trolley jack?
    cheers
    themanthatcan's Avatar
    Mar 2008
    Southampton
    665
    If I were you I'd be using ramps on the front wheels and chocks on the rear wheels. I certainly wouldn't want to be working under a car held up by a trolley jack of any kind!
    2001 S3 AMK in black - Ambient lighting kit and Aero wipers.
    Is it wrong to love your car more than your girlfriend? - When you no longer have a girlfriend it's fine!
    Shy19s's Avatar
    Oil running through my veins.
    Apr 2008
    London
    902
    In answer to your question, depending on how low your car is(i.e get right underneath and jack it up from a strong chassis point) or you can jack it up on the Sills, (should be about 3-4 inches from the corner of arch) then find an appropriate place on the body of the car to place an axle stand.
    Dont go under the car with just the trolley jack holding it up, because they can leak oil slowly while your under the car, fail and collapse.
    Especially the cheap ones.
    Totally addicted to boost.
    Jay
    Aug 2006
    323
    Right thanks, Think i'll hold on till i can source some stands.
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    ive worked on cars using a trolly jack, just put some blocks of wood under just in case.
    red to red black to black blue to bits
    cjhill's Avatar
    hmmmmm interesting.
    Aug 2005
    UK, South
    335
    good idea to have at least three points of safety - trolly jack, axle stands and i even put the wheel ive just taken off under the car too....
    but then i am a paranoid freak!
    word of caution, i used the sill to jack it up a few times and bent the metal - now its rusting so have had to take the plastic skirt off and paint it all - yes i did jack it at the jacking points.
    hope that helps
    Call of Duty Zombie Slasher.
    Jan 2007
    Hertfordshire
    520
    cjhill, its not that you jacked it up at the wrong point, its that you used the wrong jack. My mate jacked mine up with a standard trolley jack with the circular jacking point and it bent the metal, same point i'd had it lifted previous day.
    jesters3's Avatar
    The Shire's
    1,516
    Quote Originally Posted by cjhill View Post
    Fully agree with this set-up and I also use the spare wheel jack as well for the other side.
    The point I use is inside just after this sill, there are two 'rubber mounts' I use the 'round one' of the two with a block of wood as an inbetween. These 'rubber mounts' are located around the car as where points to use the jack on.
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
